Thread: Edm - RCA connector
    Sep 2010
    San Jose, California
    181
    Default Edm - RCA connector
    I have a J Pole antenna that I use this connector to plug into my EDM transmitter. After many years, this connector needs to be replaced. The problem is I don’t know what it’s called or where to get one. Can anybody help? I have my back up “rubber ducky” doing the job now but the J Pole is much better but I need this connector.
    Thanks!
    976
    Default Re: Edm - RCA connector
    Maybe this will help.
    https://www.jpole-antenna.com/2013/1...ights-display/
    Near the bottom of the page he refers to the EDM using RCA jack and your photo looks like male RCA connector. Googling male RCA connector returns hits from ebay for example that for $5 you can try one out.
    West Bloomfield, MI
    619
    Quote Originally Posted by Mangrove View Post
    Thanks!
    This is simply a male RCA connector (cost $1 to $3 depending on material type). The connector referred to in the link on the previous post is an adapter the goes from a BNC (cable type) connector to an RCA plug which I don't think you need based on the photo.
    Ed
    Happily retired
    Sep 2010
    181
    I ended up purchasing a RG58 BNC compression fitting then adding a BNC to RCA adapter to go into the EDM.
    I had no luck finding the generic RCA adapter pictured (which I think was designed for RG 59; it was always a little big) so I bought more tools (darn) and did it the right way.
    The result, I get about a mile of clear transmission in a densely populated city environment on the lowest power from my EDM transmitter.
    Thanks for the help!
