Results 1 to 8 of 8
Thread: Cutting Coroplast with CNC
    Jun 2011
    1,881
    Default Cutting Coroplast with CNC
    I have finally got my shopbot up and running so I can play with it. One of the first things I want to do is cut out some Coro shapes in 4mm Coroplast. I have tried several spindle speeds and feed rates but can't seem to get the flute tails to completely cut off. I am using an 1/8" O flute down cut bit. The top and bottom cut fine, the flutes leave small tails. I have tried a straight 2 flute bit as well with no better results.
    Anyone out there (Jim?) use their CNC to cut Coro and not leave the flute tails?
    Help!
    Craig
    Jun 2011
    1,881
    Default Re: Cutting Coroplast with CNC
    Anybody???
    Nov 2017
    127
    Curious on this as well - Can't believe no one has any info!
    Plant city, Florida
    80
    When I was researching a cnc machine for coroplast I found a few forums which talk about best settings. I think they said fast travel speed. I don't remember which forum I saw it in, just Google it you might find it.
    Sent from my SM-G950U using Tapatalk
    1,023
    Doing internet research shows:
    Using a drag knife to do it.
    https://www.youtube.com/watch?v=fOf_tCefl6Q
    This one shows a blade as well: https://www.youtube.com/watch?v=AF5TEWcpw-M
    So stop "drilling" your coroplast"
    This forum says I have had real good luck using Onsrud and Centurion O-Flutes at 8 ips 5 sheets at a time at 18000 rpm. http://www.letterville.com/ubb-cgi/u...1;t=055064;p=0
    This forum thread says to cut counter clockwise and one guy suggested using a torch to burn off the rest: http://www.talkshopbot.com/forum/sho...ting-Coroplast
    Jun 2011
    1,881
    I wound up using an O-Flute upcut bit. I only cut one sheet at a time but still have an issue with with small flute tails.
    I also got a drag knife and it works pretty well but I am not sure about cutting a butt load of hole with it.. that is going to be a bit thing..
    5,800
    Have you tried using a thin cushion layer between your corrugated work and your spoilboard ?
    Jun 2011
    1,881
    I am not sure how that would help with the flute tails between the top and bottom layers of the Coro. I tried an O-Flute down cut bit and a straight bit but neither really stopped the tails.
    I'm guessing I would have a hard time with the vacuum holding the Coro if I did that cushion I would imagine. I remember reading that James uses a piece of Coro on his spoil board, is that what you mean by a "cushion layer"?.
