Quote Originally Posted by TazChaLet View Post
looking at the way you have the things setup things over lap not sure if this really could be causing a problem but I would fix that first and retest if not I would contact Holiday coro I know they have helped a friend out with his problem last yr
Do you power-inject your lights? I noticed in the AlphaPix 4 Setup that the SPI Outputs #1 and #4 are both set at 600 pixels connected with the Intensity light level set at 100%. 600 pixels on one channel is a lot. SPI Outputs #1 and #4 may have been stressed and failed prematurely because of a lack of proper power-injection, improperly performed power-injection, or the Intensity light level set to high.
