Results 1 to 7 of 7
Thread: Need help with my new Toy
    Oct 2009
    665
    Default Need help with my new Toy
    I finally received my new 45 W RGB remote control light source. It will be primarily used to light fiber optic setup for a laminar fountain.
    See my photos here - http://laminar.forumotion.com/t72p165-my-project
    The only problem now is to get it to work. The company was kind enough to send another remote - as they thought it might be at faulty.
    I have tried the best I can to understand the Chinese to English translation in the instruction manual.
    Would anyone be able to help to get this thing going? I would also light to use it without the fiber optics as wall washer.
    Thanks in advance.
    External Links so you can view a large image of the printed material.
    http://tinypic.com/r/2ugjd3o/9
    http://tinypic.com/r/wthw12/9
    3,179
    Default Re: Need help with my new Toy
    What is it doing?
    What do you expect it to do?
    Oct 2009
    665
    With the remote it can produce these colors, fades, flashes etc.
    If I turn it on while holding in the rear button they speak about I get one "beep" and the LED is off.
    Pushing any button on the remote - as they suggest - produces a single long "beep" and "red" comes on.
    Nothing else happens - no further beeps or changes to the "red" color.
    Pushing any of the keys does nothing. There does not seem to be any "reading" of the remote taking place.
    Covewi
    3,179
    did it work the same way with both remotes?
    Kansas City Missouri
    1,930
    That's generally a generic IR remote. Needs to be pointed right at the receiver to work. I have 3 of these for my pond lights. My guess is it's the receiver that's bad.
    Winter Haven Florida
    2,897
    when you hear the first ding do you let the button go if so hold it longer the directions say you should get 2 long dings to put it into learn mode then push a button on remote and get 2 dings
    James WinterHaven Fl
    Oct 2009
    665
    Yep. Tried holding the button longer as suggested. I only get one beep. Contacted the company to see what they say.
    Is there a way I could just use the PS and RGB Led and control it via xlights and FFP?
