Results 1 to 9 of 9
Thread: pulse
    May 2018
    12
    Default pulse
    hi i was just using pulse in my elements when it changed from white to clear or grey to the same as the background and it wont play anything how can i get it back to white please
    3,547
    Default Re: pulse
    For me, in the past, that usually indicated there is an element to which you are trying to apply the pulse that does not support the color you have chosen. Most often for me this happens when I use a morphing color on strings that only support a single color. kind of like applying White to a string that only does blue. White is not all colors, it is 'white' and will not turn on a blue string.
    7,604
    Default Re: pulse
    Martin is 100% in his response. Couldn’t have said it better myself. I just wanted to confirm that Nothing has changed recently in this regard. If anything we may have made the empty box boldler so it doesn’t just disappear on the grid. But the empty box still properly indicates that the effect has no result.
    May 2018
    12
    Default Re: pulse
    i was using the ones i always use as i was only switching relays it was working fine they were all white then i was using copy and paste all of a sudden the past changed to clear the white was still there from before but all new ones was no good when i reloaded none of them would go white they all go clear and i never changed anything
    May 2018
    12
    Default Re: pulse
    ok i found that it changed colour from whit to blue and would not let me change back so i had to delete my sequence and start again thanks for the info from MartinMueller2003
    7,604
    Default Re: pulse
    What color is your element set up for? Whatever it is, that's the color you should be using in the effects on that element.
    May 2018
    12
    Default Re: pulse
    its ok im using relays
    7,604
    Default Re: pulse
    It doesn’t matter what you have connected. What matters is that your effects match the colors your elements are set up for.
    May 2018
    12
    Default Re: pulse
    i have not got that far yet i just use 3 relays to switch from one colour to the next im still learning got a long way to go
