Results 11 to 12 of 12
Thread: Tune to sign separate from show?
    Columbus, OH
    4,118
    Default Re: Tune to sign separate from show?
    Wonderful.
    I would appreciate that!
    That's the beauty of doing it with the control channel mechanism. The triggers are just channel data in your sequence and any show player/scheduler will send them out as standard lighting data. You're not limited by any particular feature set in the player. I should start a separate thread for this. I've actually explained this a handful of times in the past few weeks. I need to get it documented.
    Lombard, IL
    619
    That being said, the video sign was in use before I was running the show from FPP. That's the beauty of doing it with the control channel mechanism. The triggers are just channel data in your sequence and any show player/scheduler will send them out as standard lighting data. You're not limited by any particular feature set in the player. I should start a separate thread for this. I've actually explained this a handful of times in the past few weeks. I need to get it documented.
    Yes, Please!!! Because I know i can setup a script/trigger that will stop the background and run another over the top. That way I think I can run my sign the way I am currently am and then maybe include Sequence Titles as part of the show.
