Results 21 to 30 of 31
Thread: PVC mounting on roof edge
    Nov 2018
    Houston, Texas
    126
    Default Re: PVC mounting on roof edge
    I am currently trying different magnets and so far what I know is the ceramic magnets wont work , ordering some neodymium 3/4 round as they are stronger rare earth magnets. The number of magnets needed will determine if I call it quits or not as I have more important crap to buy lol
    Aug 2007
    MD, USA
    1,079
    I've used some of those for some of my mechanical Christmas displays, and they are super powerful. The rare Earth's have a unit for how strong they are, that does make some difference. I would be worried that it would hold too hard and getting them down would be harder than up.
    ~Jason
    [URL]http://www.tooz.us[/URL]
    Nov 2018
    Houston, Texas
    126
    Quote Originally Posted by toozie21 View Post
    I deal with robots at work that use magnets to crawl up the wall of tanks so Im pretty good with them . I used two of these to hold up 13 feet of 1/2 pvc with lights as long as you slide them off theres no problem but if you try to pull directly outward it would be tough. Plus the thickness of the metal is really thin so you loose a lot of pull force with thinner material. I just need find the right magnet at the right price to make it worth it.
    Jan 2019
    Silver Spring Shores Florida
    14
    Secure one end to a piece of PVC with a clamp or vice grips. Bend it around the pipe until you get a C shape. After that, bend the strap backward so the C drops down as shown in the picture. Clamping to a piece of wood with a 90 degree edge helps with the second bend.
    Attachment 40048
    Attachment 40049
    Attachment 40050
    dcamron can you tell me please if you use 1/2 or 3/4 inch pvc pipe? I am loving this idea thank you.
    Dave
    4
    Quote Originally Posted by BoCa View Post
    Dave
    I used 1/2" pvc. It worked great.
    Nov 2018
    Houston, Texas
    126
    Heres another way to hide out of site for 1/2 inch pvc I got bag of 1/2 couplers . With pvc cuter I cut 3/4 inch offf of both sides of coupler
    After doing that I then cut about a 3/4 section from those pieces I try to cut piece out with the bump on it
    Dont have to be perfect , then I drill a small hole w/countersink for screw
    Then test my clips on my 1/2 pvc
    Now Im ready to place under my roof line . Lights will show but wiring and pipe wont . With all my edging pre made and lights already attached to pvc I can just snap each section in place in a matter of minutes vs. hours climbing on roof . I get contractor bag of couplers qty 10 for 2.60 ish each makes 2 clips so 20 clips per bag screws are box of 100 for 5.59
    Clips stay up light bars come down just pop out . Ive labeled mine by number starting from left of house to right .
    Just an idea I puked up last year till I find better option cause I hate staples and climbing on roof and time to put those cheap clips up that always breaking on me .
    303
    Dave
    I use 3/4. 1/2 is too flexible but would probably work with enough clips and a light amount of weight. You cant see the white PVC on my house when its up there. Just the lights.
    Chambersburg, PA
    698
    Clips stay up light bars come down just pop out . I’ve labeled mine by number starting from left of house to right .
    I will be interested to know how those clips hold up for you over a couple of seasons. I have tried some purchased clips (1 season), 3D printed ABS clips (2+ seasons). I have to redo my window frames this year and I am looking for a better mounting system
    2016 - No Display
    Nov 2018
    Houston, Texas
    126
    I agree but my thinking was for 5 bucks to replace them all even at 2 -3 seasons Ill be happy . This year will be 2nd season.
    Sep 2016
    Phoenix, AZ
    19
    Im a little late here but I use 3/4" EMT 1 hole steel straps. Put a channel lock to it and bend it smaller. Snaps right onto 1/2 inch PVC like it was meant to be there. The little nub on the inside of the strap grabs and holds 1/2" PVC perfectly. If it is too loose, take it off, squeeze it some more with the channel locks until it fits tight. I use 4 straps per just under 10 foot pipes. Drilled 2 1/4" spacing to support 50 12 mm pixels each. Put a 1/2" coupler on the end to tie together each PVC length. Then permanently mount cup hooks on the eave. Takes 2 seconds to install 50 pixels. Leave the hooks up for next year. The hard part is drilling all of the holes in the pipes.................. I'll be drilling 20 more pipe this weekend.
