Results 1 to 10 of 28
Thread: Cheap ESP-01 Modules that don't work for an ESPixelStick
    Jan 2014
    23
    Default Cheap ESP-01 Modules that don't work for an ESPixelStick
    So I purchased 10 ESP-01's from Aliexpress, and they don't work. At least they don't work with the ESPixelStick code. Seems to be a common problem. Guessing not all ESP-01's are the same.
    I could flash the ESP by 'hard-coding' the spiffs file. The ESP would work the first time, but never reconnect.
    The ESP-01 I had with 'AI-Cloud Inside' works fine, no issues.
    Anyone found a use for these 'bad' ESP-01's? Or a fix to get around the connection issue?
    Are there known good ESP-01's we should be buying? I ordered more from Aliexpress with the 'AI-Cloud Inside' in the picture.
    Folsom, CA, USA
    1,725
    Default Re: Cheap ESP-01 Modules that don't work for an ESPixelStick
    Known issue. No fix for ESP Sticks yet...may never be a fix. No know way to guarantee you won’t get them again. Try domestic source- pay more, but pre tested.
    In Lights Therapy
    3,194
    Interesting. Look at the chip next to the CPU. On the working version, the chip is physically larger. If I remember the discussions, it is that chip that has the timing issue that causes the ESP-01s to fail. So if you see a picture of what you are getting, make sure it has the larger chip installed. FYI: That is not a guarantee, just something I noticed in your picture.
    Folsom, CA, USA
    1,725
    How good are you at soldering smd devices. I fixed 5 of them by floating solder with an iron.
    Chip = W25Q32FVSIG
    https://www.aliexpress.com/item/10pc...ceBeautifyAB=0
    https://diychristmas.org/vb1/showthr...ll=1#post99568
    In Lights Therapy
  5. Likes Keith R liked this post
  6. #5
    Chesapeake, VA
    735
    I think the bad chips are puma? I found you can flash the chips and they will work as long as you dont make or save changes in the web gui. Could be wrong though.
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
  7. #6
    1,229
  8. Likes mikel3332 liked this post
  9. #7
    78
    Quote Originally Posted by jaywalk101 View Post
    Manufacturer of memory chip with the problem is Puya. I was able to fix mine by replacing the memory chip.
  10. #8
    9,051
    Yes, either replace the Puya chip or hang onto them -- once the Arduino core is universally updated to use the Puya chip and current ESP firmware gets recompiled with the new core, they may work -- so don't toss them out!
    http://digwdf.com/store/
    The DIGWDF Store will be closing at the end of December -- but there's still a little stock left!
    While it's still open, please check us out for blinky-flashy gizmos that nobody else on the planet makes!
  11. Thanks Airwolf16 thanked for this post
  12. #9
    Jan 2014
    23
    Thank you all for the info.
    Dirknerkle, as I'm digging out crap from last year, I found a couple of RenardESP kits I bought from you. I dorked with them for way too long. I could get them to work and then nothing, re-flash, repeat, same result. What I noticed a few minutes ago, I have some ESP01's with the Puya chip. Well CRAP! At least I understand the issue now. And hopefully this thread will help others.
  13. #10
    5,664
    Quote Originally Posted by ucfknight98 View Post
    The Puya do work with ver 1.4 of the firmware
