Results 11 to 17 of 17
Thread: Arduino with Ethernet shield
    Mar 2017
    Clinton Twp. Michigan
    53
    Default Re: Arduino with Ethernet shield
    Thanks I will playing with it this week.
    Sep 2010
    Folsom, Ca
    90
    Quote Originally Posted by JCook View Post
    This approach is what I'm looking for to run on a WeMos D1 board with ESP 8266 chip.
    Attachment 39998
    I want to run this shield on it that controls EL Wire. I have this Board from SparkFun working from Vixen but using Serial. I want to use E1.31 so that I can use WiFi to connect 3 or 4 of these together.
    This is the shield that I want to use on the WeMos.
    Attachment 39999
    I've heard the ESPixel Stick firmware will run on the WeMos because it is the same chip and all that would need to be modified is the portion of the code that controls the output. Not being a programmer, this is difficult for me. The working sketch for the standalone board is here
    Any thoughts on using the E1.31 sketch above to control the EL Wire shield? Is this as simple as modifying the outputs from the "relays" to the Pins on the El Wire Shield? or is it a total rewrite?
    This is cool, I can't wait to see you get this working. I'm a few weeks from putting my project on here that is very similar. I'm using the Sparkfun ESP-32 Thing with Arduino and a custom SSR PCB to control light strands via wifi. I've got about 20 channels with dimming. Looking forward to your progress!
  3. Likes JCook liked this post
  4. #13
    Mar 2017
    53
    I was playing around with code made a few changes but can't stop the chattering when I run Vixen 3. I don't seem to get vixen to find this controller is seem to read my other light program not the one I want to go read
  5. #14
    Jul 2014
    Missouri
    118
    Can you ping the arduino from a command prompt to make sure you have communication from your PC?
  6. #15
    Mar 2017
    53
    I can't rape my head around what is happing .
    If I open vixen upload the sketch connect the ethernet cable from my computer go in to vixen and change the universe all works great.
    But if I close Vixen and then restart Vixen all outputs to relays go nuts.
  7. #16
    Jul 2014
    Missouri
    118
    Quote Originally Posted by AJVenti View Post
    Shoot me your sketch you have modified and screen cap how you have it setup in vixen. Once you have the sketch uploaded to the arduino you should never have to worry about uploading it again. I have three arduinos that have been the same for three years with no changes. The way the person wrote the sketch, all relays come on if there is no communication from Vixen or another sequencer.
  8. #17
    Mar 2017
    53
    I don't know how to ping the arduino from a command prompt. I did try opening a browser with up address nothing.
    What am I doing wrong?
    I loaded the sketch that jwamsley07 gave me as is. This what I get.
    Load sketch let it run test
    open Vixen
    connect ethernet cable nothing go to display change universe (Multicast nothing in Unicast) Works Great
    close Vixen restart Vixen relays chatter
    Close Vixen
    Disconnect ethernet cable
    Restart Vixen connect ethernet cable change universe Works again
    I am thinking there is something happing with the ethernet part of sketch?
    To tell you the truth I am just guessing. I have no ideal
