Results 1 to 10 of 12
Thread: DIY Coro Arch
    Jan 2014
    32
    Default DIY Coro Arch
    Made from black and natural coro with 62 led strips. I found that if I sprayed the back side with chrome/silver paint, the result was a very smooth - yet sharp - projection of light. Super lightweight and economical! I found a sign shop with 4x8 coro for $12/sht - sure beats $85 for ldpe tubing! Am able to make 8 complete arches for $24 and lots of glue!
  2. Likes tecnageek liked this post
  3. #2
    Dec 2017
    Phx,AZ
    131
    Default Re: DIY Coro Arch
    Interesting I thought about doing this as well, but how are you keeping all the arches the same curve. Did you make a coro temple to trace over and cut. That was my issue coro is a pain in the.... to cut circular. I tried this but couldn't get the arches the exact same.
  4. #3
    Washington State
    160
    Looks great. I may have to look into this.
  5. #4
    Chambersburg, PA
    685
    Quote Originally Posted by mister softee View Post
    depending on the equipment you have, you could make a hardboard template, then use a pattern bit in a router to cut as many as you want identical.
    2016 - No Display
  6. Likes dcamron liked this post
  7. #5
    Chambersburg, PA
    685
    Quote Originally Posted by gpoduska View Post
    Looks really nice! So you are using 4 pieces per arch, 2 curved and 2 with the cells running horizontally so they can curve with the arch? How big did they turn out?
    2016 - No Display
  8. #6
    Jan 2014
    32
    So... I first made a template in Inkscape (file attached) and printed out full side on several 8x11 sheets of paper. Then taped them together and cut out the outline and traced several close together on the black coro. I did half of the full arch so I can squeeze em all in a single coro sheet. Then took a utility knife and cut em all out and glued the black/back arch pieces together. I kinda went for a parabolic shape as you can see from the half arch. Overall, its almost 4 ft in diameter and 1.5 inch thick. Once i had the back part of the arch made, I took a band saw and cut many 2 inch pieces -cross flute - to make the top (clear) and bottom (black) sides. I cut through only one side of the pieces to be able to bend easier around the arch. I put the black bottom in first and then sprayed with chrome paint. I got this idea from an office eco hack where they put mirrored backing to ceiling fluorescent lights. 1 light reflected as many as 2-3, etc. The result was astounding! I was able to put the strip facing upwards around the bottom piece using the two sided adhesive on the strips which reflects off the back as well as forward for a combo of diffusion! Then i made full size front/clear arches by tracing the arch back already made. The is made for a little bit of waste, but large enough to keep for future concoctions. Using this honeycomb method is extremely sturdy once the last cap piece is on.
    For stakes, I plan on using thick piano wire and securing with a piece of coro...
    Overall I couldn't be happier with the result! I've been pondering all the various ideas and thought this was the best and most economical. Previously I used 5/8" drip irrigation hose and hula hoops with 12mm hole drilled for pixels, but found them all to be wobbly and just not up to the task.
  9. #7
    Jan 2014
    32
    Here is the file....
    Converted to jpg...
  10. #8
    Chambersburg, PA
    685
    Nice! You should talk to Brian (Macrosill) the site admin about adding this to the Wiki. I did one last year for the StarFlake Spinner, and may do another shortly for my Singing Pixel Snowmen.
    2016 - No Display
  11. #9
    Jan 2014
    32
    Some others....
    I'm on a coro kick..! I think there are great coro products out there, but I consider myself a "maker" of sorts and enjoy the fruits of my labor..!
  12. #10
    Jan 2014
    32
    Starflake spinner is awesome! Now the challenge is to make a Starflake/Spinner/Snowman/Candycane all-in-1 !!
