Results 1 to 7 of 7
Thread: sender/receiver or t-8000
    Aug 2018
    2
    Default sender/receiver or t-8000
    I figure if anyone will be able to answer this question; it is you guys.
    I have built a 128*64 pixel banner using ws2812s panels. I am using this for my band. I originally ran it with a raspberry pi and arduino but found it limiting and my sound guy wanted nothing to do with compiling and running c++ programs to run my banner. So I am looking at just creating images, small movies and light displays and sending them to be displayed on the banner. So here is where I need your help. What is the difference between a sending/receiving unit such as this
    https://www.adafruit.com/product/1453
    and a t-8000 controller such as this
    https://kutop.com/t-8000c-programmab...0aAmthEALw_wcB
    They both appear to do the same thing. The t-8000 says it will work with dmx programs; but I can't use that since I am using 48 universes ((128*64*3)/512). There also seems to be many different versions of the t-8000 running anywhere from 256 pixels a port to 1024. I need 8 ports at 1024 pixels ((128*64)/8)
    So I am guessing that many of use one or the other I am wondering about the pro's and con's of each. Bonus points if you can figure out a way I can cycle through the images using a foot controller.
    William
    3,370
    Default Re: sender/receiver or t-8000
    Raspberry PI + FPP software (free) + PI Hat makes a complete display system that can drive your grid. No C++ programming required. Next you need to use something like Vixen 3 or xLights to make a set of mini sequences that will play on your grid. You can trigger the various sequences using external inputs. This will allow your sound guy to change what is being displayed without the need to "Program" anything. Give him a set of buttons that kick off the desired sequences and you are good to go. By using one of the well known sequence generators, you can change the sequences as needed (add club / city / state names etc).
    976
    You have 8000 pixels to drive. How did you manage that with an arduino?
    To drive that many pixels with speed for "movies", you should probably think about a dedicated controller. This page has a description/comparison of the 16 port "DIY" controllers that fit your requirements. About halfway down are the pixel limits. https://xlights.org/16-port-rgb-pixel-controllers/
    You can drive the controllers using a RPi running FPP. FPP has GPIO support so you could attach a "foot pedal" and cycle the overlays/events/schedules using gpio input. You may want to run different sequences though for different songs. This would be easier to select off a "menu" from a web page. For that purpose, you could use the display test function described here: https://falcon-player.gitbooks.io/fa...y_testing.html
    None of this kind of sequencing is DJ style sequencing. For that, you might want to look at software that makes pretty patterns for you "on the fly" with stored effects. Jinx is a free software (and looks to be a couple years old now) and Madrix is one of the pay for it versions. I am sure there are others but those are two to consider.
    3,370
    Keep in mind that for real motion video, you are limited to ~600 pixels per contiguous string (no matter what the controller can do).
    Aug 2018
    2
    Jinx is windows based; which is one of the the reasons I am looking at running my laptop. Would love to use Madrix but too many universes; too much money. I was running scripts on my arduino; more like animations, this is how I got around the pixel problem. This why I am I am looking at the t-8000 and adafruit hardware. Jinx should recognize the t-8000 and the t-8000 can do 512 pixels a port; so I would be right at my max. I am leaning towards the t-8000 unless there is a good reason to use the adafruit technology.
    My thought is any dj style animations. I would work up ahead of time and save them also as a short looped movie. So that said, you guys are the people who understand this far more than me; what would you suggest?
    3,370
    The F16V3 is cheaper per port than the T8000.
    Jul 2015
    319
    Xlights has a bunch of live show features and the ability to be controlled either by external hardware or even a midi panel.
