Results 1 to 9 of 9
Thread: SSC-32 plugin
    20
    Default SSC-32 plugin
    I am looking to purchase a SSC-32 to operate a 3 axis skull with Vixen. I have seen stated that it will work with the Minissc plugin.
    Is anyone using this setup? I have been using Vixen for several years and would like to continue to do so. I have searched this forum and the Halloween forum and have not been able to find any thing solid about setting this system up. I have also not been able to find a place to down load
    the Minissc plugin.
    Any help would be appreciated.
    thks
    Houston, TX (near Katy)
    927
    Default Re: SSC-32 plugin
    I think LynxMotion still makes these, but it may be a USB version instead of the serial port version.
    http://www.lynxmotion.com/p-395-ssc-...ontroller.aspx
    This might be of interest to you.
    That's a feature not a bug.
    There's no charge for that.
    7,579
    Thatís not an output type we have in V3. But that being said, I know nothing about it. Does it by any chance use a standard protocol?
    20
    The SSC-32 I am looking at has a USB connection. I have read that it will run with a Mini-SSC plugin for VIXEN.
    As I stated above I am unable to find this Plugin. Has anyone heard of it?
    I went ahead and ordered the SSC-32 today, so the commitment has been made. Now the scramble to get it to work.LOL
    976
    976
    The original version of this seems to be simple. The lynxmotion version is a bit more complicated. Both appear to be standard serial output.
    The original version was sync (xFF), server 0-7, and position (0-254).
    The lynxmotion uses # <ch> P <pw> ​S​ ​<spd>​ ​T​ <time> <cr>
    ● <ch>: pin / channel to which the servo is connected (0 to 31) in decimal
    ● <pw>: desired pulse width (normally 500 to 2500) in microseconds
    ● <spd>​: servo movement speed in microseconds per second*
    ● <time>​: time in microseconds to travel from the current position to the desired position.
    This affects all servos (65535 max) *
    ● <cr>: carriage return (ASCII 13)
    927
    I do use the SSC-32 (serial) to run my skeleton quartet, but I program in VSA and use Haunt Monkey's Helmsman to start the programs. Seems like there is also a program called VSA console that is needed. I used the MiniSSC (0-255) and Vixen 2.1 once to use the Pololu board which worked very well. Here is a link to one of my vids. Good luck!
    20
    Sorry for not getting back sooner. I found the download from the Vixen 2.0 version and loaded it into the Vixen 3.5 I am using and it locks up the program when I try to use it. It comes up as a Parallax servo controller. really wish it would work as I'm familiar with Vixen and like the ease of using it. Anymore ideas?
    7,579
    Quote Originally Posted by copterdocc View Post
    Vixen 2 plugins will not work in vixen 3. Itís a completely different program.
    There is a PSC controller in Vixen 3. But itís specific to the parallax servo controller board. We do not have a plug-in for the board you have.
