Results 1 to 9 of 9
Thread: Window Frames
    Feb 2018
    Westport, MA
    19
    Default Window Frames
    I am putting together my first show for this year, which includes 112 channels spanning two houses that are side by side. While it is evident that pixels are very popular, I prefer the classic LED. (don't crucify me)
    I needed a solution to hang lights on the windows without damaging them, as well as an easy way to store and put up each year.
    As you can see from the first picture below there is a small gap between the frame and the side of the house. My plan was to make a PVC frame and a custom bracket to go over the window protrusion. I was able to bend the metal with just a vice grip. Below is what I came up with.
    Materials:
    1/2" PVC and fittings
    Spray paint and clear coat
    Aluminum strips
    Drill
    Rivet gun and rivets
    Lights
    Zip ties
    I attached the brackets using rivets through the predrilled hole in the back and pipe. I put two on the top of each frame and one in the middle of each vertical pipe.
    Sent from my Pixel 2 XL using Tapatalk
  2. Likes daveaase liked this post
  3. #2
    2,708
    Default Re: Window Frames
    Quote Originally Posted by MaynardFerguson View Post
    No worries there. It is actually refreshing to see someone building a new project with traditional lights.
    I like it. One thing though, what about wind? Will the frame swing in and out? Do you need anything to hold the frame at the bottom as well?
  4. #3
    Feb 2018
    Westport, MA
    19
    It is really tight. The brackets on the vertical pipes hold it really well. I had it sitting outside for a month before moving forward.
  5. #4
    Concord, North Carolina, USA
    231
    I'm glad to see someone has my same situation. I use aluminum angle to hang the pvc frames above the windows and door. They are larger than the window frame.
    Have had no problems, they just hang there until I take them down. Hope this helps.
    Take what you can, give nothing back!
    2010 - First Attack - Success!
    2011 - Survived Second Attack!
    2012 - In Total Control
    2013 - Calm Sailing
    2014 - I feel a change in the wind
    2015 - no show - Got lazy in Paradise
    2016 - Back on course
    2017 - no show - Laying in a New Course
    2018 - Hard to Remember
    2019 - Ah, Calm Lights on the Horizon - static
    2020 - Maybe? (Back in Friendly Seas)
    http://www.dreamweaverholidaylights.com/
  6. #5
    houston, TX
    450
    https://www.homedepot.com/p/10-ft-Vi...CB10/202093365
    you put the lights onto the plastic with either Zipties or hotglue. And you make 90deg by simply cutting one side with tin snips and folding it over on itself, then gluing it to shape. A few pieces of Velcro to keep the wind from blowing it off, and you're done. Just slip it over the frame in a single piece with cord coming down the bottom.
    Easy to build, Easy to install, lasts forever, cheap
  7. Thanks daveaase thanked for this post
  8. #6
    Chambersburg, PA
    703
    I use a similarly shaped bracket to support several of my props. One advantage is that I can take down my 2nd story window frames and other decorations using only a long paint pole with a hook on the end and no ladders.
    2016 - No Display
  9. #7
    central MO
    79
    Can you take a picture of how you attach led the hooks to house and such?
  10. #8
    Feb 2018
    Westport, MA
    19
    Quote Originally Posted by amrutherford2012 View Post
    There is a gap between the house and the window, enough for the bracket to hang behind.
  11. #9
    Jun 2015
    Clarkton, NC
    62
    Great idea!
