Results 11 to 18 of 18
Thread: DMX with Arduino
    3,080
    Default Re: DMX with Arduino
    The problem in general with DMX is that it uses a fixed data rate of 250000 bits per second. and a max frame size of 512 channels. This gives you a max number of pixels of about 170 in a single string. And that is if your software is working perfectly. If you use E1.31 then the number gets larger, but the Arduino is not going to run a whole lot more pixels than that. The Renard and Simple Serial protocols have no inter-frame gaps and support higher data rates (aka more pixels). How many more depends on how good your sketch is.
    There are many sketches on this site. I posted a Simple Serial sketch for someone else about two weeks ago. It was for relays but could be easily adapted to pixels.
    The most cost effective solution is to skip the Arduino and get a Pixel PI Hat (you can find them on this forum as well). The PI hat mounts on top of the PI and gives you many hundreds (I have tested to 400 others claim over 1000) pixels driven without the extra cost of an Arduino.
    Mar 2017
    Clinton Twp. Michigan
    49
    MartinMueller2003
    I want to control 16 relay not pixels if you could point me to that Simple Serial sketch I would be very happy. I want to in put from my E1.31 bridge (Renard or DMX) out put to the Arduino to work 16 relays that will be working my A/C lights. If you think this sketch could do that I would love to have it, so I can play with it to see if I am on the right path.
    3,080
    It is a sketch for four relays. Easily changed via some tables for more relays.
    http://doityourselfchristmas.com/for...e-installation
    Mar 2017
    49
    I don't know if you tried to show me the sketch or not nothing showed up
    UK S80 postcode
    1,337
    Hi, the post with E1.31 -> Arduino -> upto 16 relays is linked below. This was a development thread so it waffles a bit, it also coveres E1.31 -> Arduino -> DMX and E1.31 -> Arduino -> Pixel (hence the name). The sketches are the posts in the 30s but reading up to them will give you an insight. Whilst I said this was a development thread I've had confirmation that all three sketches are working well for others, if you need any help let me know.
    https://www.diychristmas.org/vb1/sho...ll=1#post90440
    3,080
    I sent a link to the thread. I just clicked the link and it went to the correct post.
    Nov 2017
    7
    Hi, does it have to be a DMX into the Arduino or would E1.31 -> Arduino -> relay work? I did a project for this last year.
    Attachment 39905
    Barnabybear, this is exactly what I am looking for E1.31 to Arduino to relay. Do you have details? Can you point me in the right direction?
    UK S80 postcode
    1,337
    Quote Originally Posted by KingChaos View Post
    Hi, the link is in post #15. If you need any help PM me or start a new thread.
