Thread: Pixel pop tiny red always on
    Nov 2015
    Davenport, IA
    168
    Default Pixel pop tiny red always on
    I've finally gotten around to building 2 pixel pop tiny controllers. Got them both powered with 12 volts and pixels attached. As soon as the power supply is turns on, the pixels turn on in a very dim red. The red goes away when each pixel is lit with any color but if the pixel is supposed to be off, it has the red hue. Any ideas what would cause this? I am powering the pixels through the board and have not tried powering them separately.
    UK S80 postcode
    1,285
    Default Re: Pixel pop tiny red always on
    Hi, check your voltage. I suspect it is slightly above 12V, if this is the case back it off to something like 11.9V and the red glow should go away.
    Nov 2015
    Davenport, IA
    168
    That's exactly what it was. Feel a little silly for not thinking to check that. Thank you for the help!!
    UK S80 postcode
    1,285
    Hi, no problem. The combined knowledge of a group is a great thing.
