Results 1 to 6 of 6
Thread: ubiquiti nanostation loco m2 question
    Chesapeake, VA
    733
    Default ubiquiti nanostation loco m2 question
    Have a question for the wireless guys. I've gotta handful of ESP2866's this year I want to use in my show. I see a lot of folks like the ubiquiti nanostation loco m2 and have success. With that said, I'm reading that these AP's are more directional. How do you guys position these things in your yard? I'm thinking about mounting it right under the front porch. If I have my esp2866s positioned all over my yard and house, will the nanostation loco m2 still work good? Thanks!
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
    Chesapeake, VA
    733
    Default Re: ubiquiti nanostation loco m2 question
    Or what about one of these if I mounted in a water proof enclosure and had the antenna sticking out?
    biquiti airGateway LR Wireless access point 802.11 b/g/n
    https://www.amazon.com/dp/B00HXT84UO/ref=dp_cerb_1
    Folsom, CA, USA
    1,507
    I use a PicoStation M2 - same, except Omnidirectional
    In Lights Therapy
    Feb 2017
    Ohio
    7
    I use the ubiquiti nanostation loco m2 and was a little worried about it being directional as well. My show was running in the front yard and I was able to pick up and use the signal on the back deck with no issues. I did not test the strength or anything but was surprised by that being the case. I did have a couple of esp's behind it in the front yard and they had no issues.
    8,957
    I used a Nanostation Loco M2 last year. This is an overhead view of my setup. With 46 ESP's out in the yard, only one didn't work and that was because I put it in a place that couldn't possibly work -- around a corner outside of the general coverage area and behind metal siding, to boot. My Nanostation was mounted outdoors about 8' off the ground.
    The Nanostation is a terrific product. Highly recommended.
    http://digwdf.com/store/
    The store were you can find blinky-flashy gizmos that you never knew existed!
    Folsom, CA, USA
    1,507
    Here is why I needed to go PicoStation. rough sketch with some ESPixelSticks placed to show required spread. L shaped house is a killer for wifi antennas.
    Big circle is my needed coverage which PicoStation covers.....The red arch is NanoStation. Since it doesn't go thru walls very well, I have no opportunity for the unidirectional device...unless I did 2
    In Lights Therapy
