Results 1 to 4 of 4
Thread: UDP Output Module
    Sep 2010
    Folsom, Ca
    90
    Default UDP Output Module
    Disclaimer: This isn't a "standard" output module and using it will blow up all your LEDs and incandescent lights.
    This is a generic UDP output module.
    The output format is simple and separated by a period.
    For example: Header.0.0.0.0.0.0.0.Footer
    Use a split function or split string to separate the data anyway you want.
    You can easily verify output using a free UDP monitor online such as Packet Sender or even an app on your mobile phone.
    I've only tested the module on a Windows 10 64-bit PC and it currently works with Vixen 3.0 3.4u3.
    Place UDPtaco.dll in: C:\Program Files\Vixen\Modules\Controller
    Let me know how to improve it if you find any issues.
    Happy Blinking
    Attached Files Attached Files
    Jun 2017
    34
    Default Re: UDP Output Module
    Hi Gorak,
    Thanks for sharing.
    I have a question out of the topic.
    I am a fresh programmer and would like to develop vixen module for trial, but i have no idea how to start. Do you have any advice.
    Thank you.
    Maryville, Illinois
    1,608
    Quote Originally Posted by fai.kfc View Post
    Hi Gorak,
    Thanks for sharing.
    Thank you.
    The core of all modules are very similar and you can generally model a new one from an existing one that has similar functionality. Included modules are organized by functionality in the code so similar ones are grouped together. i.e all controllers are grouped together. So grab the code from git, get it building and try to familiarize yourself with it and then post questions here and someone will be happy to help.
    Jun 2017
    34
    Thanks Jeff.
    I just import the latest dev build to visual studio and learning the code. It is impressed to me that you guys built a such huge project. Thanks Vixen team.
    Sent from my LG-H990 using Tapatalk
