Results 1 to 10 of 13
Thread: Confused about power supply. 24v PS using buck converters down to 5v.
    Oct 2015
    12
    Default Confused about power supply. 24v PS using buck converters down to 5v.
    So lets say I'm going to have 450 5v pixel nodes ran off a power supply. 3 amps per string totaling 27amps at 5v. How do I figure out what amperage/wattage 24v power supply I would use? I tried using ohm's law but I just can't seem to get it.
    5,692
    Default Re: Confused about power supply. 24v PS using buck converters down to 5v.
    Save yourself $$$ both on hardware and hydro
    Use 5v 60 power supply
    Oct 2015
    12
    I was originally going to do that but getting 5v's to the far strips would need some serious wire gauge. Or am I doing something wrong?
    976
    Assuming perfect conversion,
    5v @ 27A = 135 w
    24v @ 135w = 5.625A
    Throwing a bunch of bucks into the mix and you will likely use a bit more.
    Here is where I found the calculator.
    https://videos.cctvcamerapros.com/vo...tts-conversion
    3,424
    Power / voltage = current.
    Buck converters are about 80% efficient.
    Yes you can use smaller guage wire with less loss using a higher voltage. My show has over 60 buck converters in it.
  6. Likes plasmadrive liked this post
  7. #6
    Oct 2015
    12
    5v @ 27A = 135 w
    24v @ 135w = 5.625A
    Makes complete sense how you figured that out, thanks!
  8. #7
    Jun 2011
    1,876
    a few years back I wrote this informal paper that might help you.
    I hope it attached
    Attached Files Attached Files
  9. #8
    278
    Can you give any links/info on the buck converters you're using? I've tried 3 different types and none of them work so far. I order them in quantities of 5 so I have 15 defective buck converters. They don't drop the voltage at all.
  10. #9
    Folsom, CA, USA
    1,797
    If you have 3 different lots of defective Bucks, you likely have an installation issue.
    I like using smaller area transformers...usually weatherproof. 120V go a long, plus the transformer usually fixes voltage drop. I have no oversized wire in my layout.....but I have a lot of 120V, and much more efficient.
    In Lights Therapy
  11. #10
    278
    I wish that was the case. These don't work on the bench, right out of shipping. The ones I have are based on an LM2596 and usually fail in a fully closed state. The trim pot was the culprit in one batch but the other 2 batches seem to have bad regulators. Given the price and quality I suspect they have some counterfeit parts. I have a dozen TI LM2596's on order but still don't trust the circuit .
