Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: DIY Singing Faces more questions
    3,913
    Default Re: DIY Singing Faces more questions
    At 193 pixels per prop, you can easily do full motion video (25ms refresh rate) with three props on a port. Since you have four props, I would put two on each prop just because I like the symmetry.
    182
    oh, anotherthing though, 193pixels will be drawing roughly 12amp, and the e682 comes with 5amp fuses.
    107
    That is how I am doing them, yes
    Kansas City Missouri
    2,186
    Quote Originally Posted by MrDudeMan View Post
    That's at 100% white. You'll probably find yourself lowering the output to 50% or under because the colors look more pleasing. 100% brightness all anyone sees is a big glob of light. I run my show at 25% and the advantage to that is I can run more pixels with less power injection and I got rave reviews that my show looked much better this year because of the lower reduction. No one went home blind.
    107
    Thanks for the tip
    Nov 2017
    137
    Started my show at 30% - ended up dropping to 25%....took video at 15% for the Xlights around the world submission
    3,913
    My show is also running at reduced brightness. However, I hate going out in sub zero F temps to replace a fuse. I design everything to run at 100% and choose to run at a lower value.
