Results 31 to 35 of 35
Thread: DIY E1.31 Bridge and Pixel extender setup
  1. #31
    Sep 2009
    Omaha, Ne
    3,131
    Default Re: DIY E1.31 Bridge and Pixel extender setup
    Yeah a hard reset. There is really nothing that will change as far as the timings go ect but I am wondering if maybe a configuration parameter is causing the offset values to be read wrong and its sending the wrong area of data to the pixels. Just guessing here since updating to the 400ms timing fixed others with the issue.
  2. #32
    Lombard, IL
    598
    If it helps, I have been using your 12v ws2811 square pixels for most all of my other props. They are working fine.
  3. #33
    Sep 2009
    Omaha, Ne
    3,131
    I received the test string and have identified the problem. The core timing of the bits was changed alittle bit to resolve the problem. I tested with this years and last years pixels that had the new reset timing and both work now. Please try this 4.04 (Not found! HAH) version and verify it works for you and I will post it in the Wiki.
    Attached Files Attached Files
  4. #34
    Lombard, IL
    598
    SUCCESS!!! New eeprom works! Tested will all of my strings on the prop. Works great. Have not tried with older strings yet but problem with new one's has been resolved. Thanks Dave for the update/fix.
  5. #35
    42
    Version 4.04 fixed my problem as well. Thx
