Results 1 to 7 of 7
Thread: shorten LED strings
    739
    Default shorten LED strings
    I have some LED shortener boards I bought a while back and I never could really wrap my head around using them. I finally have a good project to use them on to shorten some left over 50 count warm white full wave LEDs from 50 to 25. I need to drop it really to 20 but I figure half would be easier and just tape over the extra lights.
    Is there a guide on figuring out what resistors I need to use in the board to shorten the string like that? I can't get a good grasp on it from what I've read so far.
    Thank you,
    Jason
    Jan 2010
    Omaha, NE
    1,929
    Default Re: shorten LED strings
    Look at the string and if there is a spot where there is only 2 wires between the led lights you can cut the string there and add a plug on it.
    Doug
    Having Fun with Wire Frames and Lights.
    www.wireframedlites.com
    Custom Hand Made In USA
    FaceBook:
    http://www.facebook.com/wireframedlites
    Phillips Family Display
    http://www.facebook.com/phillipsfamilydisplay
  3. Thanks JasonPortwood thanked for this post
  4. #3
    Springville, Utah
    521
    Quote Originally Posted by Dougp View Post
    You usually can't cut full-wave apart like that.
    For 50 ct string comprised of 2 25ct sections, there will be three "blobs". Each new section requires two such 'blobs'.
    This can be done, but you have to cut one section with two blobs, and then on the other section - that only has on blob - you have to complete the bridge with a couple diodes and usually a resistor.
    I posted a full-wave circuit diagram awhile back - that helps make it clear.
    Jimboha
    As for shortening the segments from 25 to 20: typically for white LEDs you can substitute one 220 ohm 1/4 watt resistor per LED. If you do all of your strings the same, then they will dim the same as each other, though perhaps just a little differently from an un-modified string.
    Springville, Utah
  5. Thanks JasonPortwood thanked for this post
  6. #4
    739
    Thank you both for the replies. It makes a lot more sense now. I'll look up the diagram.
    Jason
  7. #5
    1,263
    Quote Originally Posted by jimboha View Post
    This can be done, but you have to cut one section with two blobs, and then on the other section - that only has on blob - you have to compete the ridge with a couple diodes and usually a resistor.
    Jimboha
    As for shortening the segments from 25 to 20: typically for white LEDs you can substitute one 220 ohm 1/4 watt resistor per LED. If you do all of them the same, then they will dim the same as each other, though perhaps just a little differently from an un-modified string.
    Actually my cheap Wal-Mart 100 & 70 count LED strings that I have gotten the last couple of years don't have any blobs, they have 2 or 3 sections (depending on the color) where you can just cut the 2 wires and add a plug.
  8. Likes Dougp liked this post
  9. #6
    Springville, Utah
    521
    Are they full-wave?
    The half-wave Walmart LEDs I use do have over-sized sockets on each segment. That socket that has a plug cap with resistor inside.
    With those strings you can do exactly what you said. But the OP said he had full-wave strings.
    Jimboha
    Springville, Utah
  10. #7
    Springville, Utah
    521
    I found them right here in this forum:
    http://doityourselfchristmas.com/for...400#post410400
    Jimboha
    Springville, Utah
