Results 1 to 10 of 22
Thread: Espixelstick and Home Assistant
    Montreal, Canada
    17
    Question Espixelstick and Home Assistant
    Hi,
    I've decided to try and get my espixestick working with MQTT and home assistant. I don;t know much about HA or using MQTT, so this is what I have tried.
    I made an Ubuntu Server VM and installed HA following these instructions. Got it running no problems.
    I then added the following to configuration.yaml :
    Code:
    mqtt:
    light:
      - platform: mqtt
        state_topic: "matrix/esps/light/status"
        command_topic: "matrix/esps/light/switch"
        brightness_state_topic: "matrix/esps/brightness/status"
        brightness_command_topic: "matrix/esps/brightness/set"
        rgb_state_topic: "matrix/esps/rgb/status"
        rgb_command_topic: "matrix/esps/rgb/set"
        brightness_scale: 100
        optimistic: false
    Restarted HA and now I have the light button.
    I configured the espixelstick as follows:
    However, when I try and turn on the light. nothing happens. The slider switch on the console goes on and then right back off. Any ideas? Something wrong with my config? I also don't seem to have a color picker.
    Montreal, Canada
    17
    Default Re: Espixelstick and Home Assistant
    I think I just found my problem, there was an extra "/" in my topic. I corrected it as follows and now it works!
    Oct 2015
    12
    Glad you got it working. I'm just beginning using pixel nodes and I want everything to run through Home Assistant. Thanks for your work.
  4. Likes studiopro liked this post
  5. #4
    Washington State
    149
    Hello, I have been working on this for some time and I could really use some help.
    In hassio I have created a binary sensor that communicates with a light sensor that can go into "isdark" state if the lux goes below 100.
    I then tried add an automation that when "isdark" activates it sends and on state to the EspixelStick and have lights come on. I can get my "isdark" state to on and I can manually turn on lights but can't get lights to trigger from "isdark".
    Below is parts of my config.yaml
    Code:
    light:
    #espixelstick subnet 110
      - platform: mqtt
        brightness: true
        flash: true
        rgb: true
        optimistic: false
        qos: 0
    	sensor:
    #Light sensor
      - platform: mqtt
        state_topic: "bruh/sensornode1"
        ##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
        unit_of_measurement: "LUX"
        value_template: '{{ value_json.ldr }}'
    # Binary Sensors
    binary_sensor:
      - platform: threshold
        entity_id: sensor.sn1_ldr
        lower: 100
        hidden: true
    #Groups
    group:
      sensor_node_1_card:
        name: Sensor Node 1
        entities:
          - sensor.sn1_temperature
          - sensor.sn1_humidity
          - sensor.sn1_ldr
          - light.sn1_led
    automation:
    - alias: EspixelStick110 On
      trigger:
        - platform: state
          entity_id: binary_sensor.isdark
          to: 'on'
      condition:
        - condition: state
          state: 'on'
      action:
        - service: mqtt.publish
          data_template:
            topic: "matrix/esps"
            payload: '{"state":"ON"}'
    - alias: EspixelStick110 Off
      trigger:
        - platform: state
          to: 'off'
      condition:
        - condition: state
          state: 'on'
      action:
          data_template:
            payload: '{"state":"OFF"}'
    script: !include scripts.yaml
    Any insight would be deeply appriciated
  6. #5
    Oct 2015
    12
    Quote Originally Posted by tecnageek View Post
    Code:
    light:
      - platform: mqtt
        brightness: true
        flash: true
        rgb: true
        optimistic: false
        qos: 0
    	sensor:
    #Light sensor
      - platform: mqtt
    # Binary Sensors
    binary_sensor:
        lower: 100
        hidden: true
    #Groups
    group:
      sensor_node_1_card:
        name: Sensor Node 1
        entities:
          - sensor.sn1_ldr
          - light.sn1_led
    automation:
      trigger:
        - platform: state
          to: 'on'
      condition:
        - condition: state
          state: 'on'
      action:
          data_template:
      trigger:
        - platform: state
          to: 'off'
      condition:
        - condition: state
          state: 'on'
      action:
          data_template:
    I would suggest posting this question here https://www.reddit.com/r/homeassistant/ or on the official home assistant forums. They should easily be able to tell you what is going on. I'm still to new with home assistant to be of much help.
    I've found both to be great communities full of knowledge.
    I don't want to draw people away from this forum. I really think everyone's light setups should be combined with home automation software so any member of the house can start/stop/change the show.
  7. #6
    5,800
    Code:
    light:
      - platform: mqtt
        brightness: true
        flash: true
        rgb: true
        optimistic: false
        qos: 0
    	sensor: <<<<<<<<<
    #Light sensor
      - platform: mqtt
    # Binary Sensors
    binary_sensor:
        lower: 100
        hidden: true
    #Groups
    group:
      sensor_node_1_card:
        name: Sensor Node 1
        entities:
          - sensor.sn1_ldr
          - light.sn1_led
    automation:
      trigger:
        - platform: state
          to: 'on'
      condition:
        - condition: state
          state: 'on'
      action:
          data_template:
      trigger:
        - platform: state
          to: 'off'
      condition:
        - condition: state
          state: 'on'
      action:
          data_template:
    is your sensor: in the correct location ?
    i know nothing about hassio , just curious as to why the indent
  8. #7
    Washington State
    149
    Yes, the indentation is correct. All sensors are working, just not able to get them to talk with the espixelstick.
  9. #8
    Washington State
    149
    So I was digging around and noticed the “The service dev tool” in Hassio and was able to come up with a working automation.
    Now I need to be able to figure out how to send a color, and possibly send different colors based on different environmental variables.
    Code:
      trigger:
        - platform: state
          to: 'on'
      action:
        - service: homeassistant.turn_on
          entity_id:
            light.pixelstick110
      trigger:
        - platform: state
          to: 'off'
      action:
        - service: homeassistant.turn_off
          entity_id:
            light.pixelstick110
  10. #9
    Columbus, OH
    4,228
    Can you only have two options?
    Why not tell Alexis: "turn lights green" instead of "saying turn lights on"
    Code:
      trigger:
        - platform: state
          to: 'on'
      action:
          entity_id:
            light.pixelstick110
      trigger:
        - platform: state
          to: 'off'
      action:
          entity_id:
            light.pixelstick110
  11. #10
    Williamsburg, VA
    917
    This is an interesting post. I'm setting up home assistant for my house, never thought of connecting to pixel controllers.
