Results 11 to 17 of 17
Thread: Espixelstick and Home Assistant
    Washington State
    103
    Default Re: Espixelstick and Home Assistant
    I have a few strands of lights around the yard that I want to automatically after dark. Eventually I would like to send colors and patterns based on weather lighting and other variables. I would be very interested in what others come up with.
    Oct 2015
    12
    Quote Originally Posted by tecnageek View Post
    In terms of just having automatons for lights to come on and off with home assistant it's fairly straight forward. As long as your hardware is compatible. Check out Dr zZs videos and bruh automation to give you an idea of what you can do with pixel nodes and led strips.
    Aug 2012
    Charleston, SC
    1,055
    Just a heads up, ESPixelStick MQTT support now uses mqtt_json. Config example has been updated in the README.
    -shelby
    Columbus, OH
    4,055
    nice!
    Quote Originally Posted by sporadic View Post
    -shelby
    Washington State
    103
    Upgrading to latest release and testing. https://github.com/forkineye/ESPixelStick/releases
    I did get an automation up and running, but with new release I hope to utilize effects.
    Washington State
    103
    Looking pretty good. Lights are coming on after dark, and I will be working on adding different variables for colors and effects.
    Code:
    #ESPixelstick yaml
    mqtt:
      broker: !secret mqtt_broker
      port: !secret mqtt_port
      client_id: !secret mqtt_client_id
      username: !secret mqtt_username
      password: !secret mqtt_password
    light:
    #espixelstick subnet 110
      - platform: mqtt_json
        state_topic: "patio/esps"
        command_topic: "patio/esps/set"
        brightness: true
        rgb: true
        effect: true
        effect_list:
          - Solid
          - Blink
          - Flash
          - Rainbow
          - Chase
    #espixelstick subnet 109
        state_topic: "frontwalk/esps"
        command_topic: "frontwalk/esps/set"
        brightness: true
        rgb: true
        effect: true
        effect_list:
          - Solid
          - Blink
          - Flash
          - Rainbow
          - Chase
    sensor:
    #ESP_Node Temp, Light and Humidity sensors
      - platform: mqtt
        state_topic: "bruh/sensornode1"
        name: "SN1 Humidity"
        unit_of_measurement: "%"
        value_template: '{{ value_json.humidity | round(1) }}'
      - platform: mqtt
        ##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
        unit_of_measurement: "LUX"
        value_template: '{{ value_json.ldr }}'
      - platform: mqtt
        name: "SN1 Temperature"
        unit_of_measurement: "°F"
        value_template: '{{ value_json.temperature | round(1) }}'
      - platform: mqtt
        name: "SN1 Real Feel"
        value_template: '{{ value_json.heatIndex | round(1) }}'
    	# Binary Sensors
    binary_sensor:
      - platform: threshold
        entity_id: sensor.sn1_ldr
        lower: 100
        hidden: true
    groups:
      Yardlights_Card:
        entities:
          - light.ESPixel109front
          - light.espixel110patio
    #turn lights in yard off and on via isdark               #
    - alias: Yard Lights On                                  #
      trigger:                                               #
        - platform: state                                    #
          entity_id: binary_sensor.isdark                    #
          to: 'on'                                           #
      action:                                                #
        - service: homeassistant.turn_on                     #
          data:                                              #
           entity_id: group.yardlights_card                  #
           brightness: 255                                   #
           rgb_color: [255,204,255]                          #
           transition: 1                                     #
    - alias: Yard Lights Off                                 #
      trigger:                                               #
        - platform: state                                    #
          to: 'off'                                          #
      action:                                                #
        - service: homeassistant.turn_off                    #
    Aug 2012
    Charleston, SC
    1,055
    We're just starting to revamp the way effects are handled so that they can be customized via the UI. There's discussion on it in this issue thread - https://github.com/forkineye/ESPixelStick/issues/117.
    thanks,
    -shelby
