Thread: ESPixel Stick & ESPixel Pops with 5050 rgb Led Strips?
    May 2017
    Portugal
    41
    Cool ESPixel Stick & ESPixel Pops with 5050 rgb Led Strips?
    Hello
    I've ESPixel pops with WS2812B and everything is working ok.
    Now my questions are:
    - Is there a way to make it work with 5050 RGB Led strips?
    - Or should i forget about it because it doesn´t worth the investment?
    Thanks for your thoughts
    Zelev
    UK S80 postcode
    1,255
    Default Re: ESPixel Stick & ESPixel Pops with 5050 rgb Led Strips?
    Hi, have you done any Arduino work or any electronics?
    May 2017
    Portugal
    41
    Why do you ask that?
    May 2017
    Portugal
    41
    Hi, Didn´t understood your question... but i've done this:
    http://doityourselfchristmas.com/for...ith-2-arduinos
    i have no problem with arduinos (except coding ) and no problem soldering.
    Also developed my "simple pcb board".
    Any suggestion to my question about ESPîxel and 5050 rgb led strips?
    Best Regards
    Zelev
    5,463
    yes > suggestion
  6. Thanks zelev thanked for this post
  7. #6
    May 2017
    Portugal
    41
    Thanks angus40
  8. #7
    Feb 2017
    Ohio
    5
    I have used these types of strips https://www.ebay.com/itm/WS2811-5050...N7yhv8OTkOnJoQ with the ESPixel Stick the only configuration change I needed is they are not RGB the order is different and you need to change it in the ESPixel setup, or you can change it in vixen they work fine without changing but the color doesnt match what color you select in your sequence other than white. Once you change the color order you can get the colors to match up.
  9. #8
    1,092
    Are you talking about dumb RGB strips? if so then no they will not work. You can add the WS2811 chip and and an RGB Amplifier )the WS2811 chip does not put out much power) and you can then use the PixelSitcks to control them.
    ps: get the connector for the Amplifiers too.
  10. Likes angus40 liked this post
  11. #9
    Aug 2012
    Nova Scotia, Canada
    1,508
    I remember Shelby doing a hack to allow the ESPIXELSTICK to run Dumb RGB using some RS485 boards as well:
    http://www.diychristmas2.org/vb1/sho...t=espixelstick
    But I think Ruppro's suggestion is easier....
