Results 1 to 6 of 6
Thread: Can I?
    Kansas City Missouri
    1,789
    Default Can I?
    Right now I'm using a 682 for a pixel tree utilizing all 16 outputs. I'm running 2-12 volt 350 watt power supplies. 16 strands of 55 pixel each. I'm curious if I can get away with 1 power supply if I'm running the pixels at 25%? These are square pixels and I think the wattage if each is .6 watts.
    Chambersburg, PA
    515
    Default Re: Can I?
    Everything I have seen is that the power consumption of pixels is in direct proportion to the "Brightness" level you are running, so at 25% you should be able to run close to 4X the pixels on the same power needed @ 100%.
    2016 - No Display
    1,789
    Default Re: Can I?
    I kinda thought the same thing. Thank you.
    Jan 2013
    Tucson, AZ
    972
    Default Re: Can I?
    I don't think it will be an exact ratio like that. I remember testing current draw on my 270 pixel star and even with the pixels off it was pulling 1 amp so you will have a base current draw regardless of the power setting.
    Didn't pay for a sig
    Nov 2007
    Houston, TX (near Katy)
    854
    Default Re: Can I?
    I ran 100% with an e682 with a 16 x 50 tree on one power supply until this year. I changed to 50% because I could with the new e682 software. I never seemed to have any issues but I didn't run full white very often. The only reason I did it was because I saw David Pitts doing it (one power supply on a 16x50) at a Christmas Expo near Dallas a few years back. I also ran both square and bullet pixels the same way.
    That's a feature not a bug.
    There's no charge for that.
    1,789
    Default Re: Can I?
    Quote Originally Posted by Keith R View Post
    25% does really well for me. One can see the separate colors and not one big blob of color. Extremely pleasing to the eye.
