Results 1 to 9 of 9
Thread: Two Renard Plus TR24 controllers for Sale
    May 2016
    48
    Default Two Renard Plus TR24 controllers for Sale
    I’ve got two TR24’s that I don’t need. I got these as part of a bulk purchase with some other equipment. I’ve powered them on and get a red power light. I haven’t tested them otherwise.
    I’m thinking $110 each shipped CONUS. The board and 24 tails are included. I want to keep the boxes, but will throw them in and keep it assembled for an additional $20 each.
    Board #1
    May 2016
    48
    Default Re: Two Renard Plus TR24 controllers for Sale
    Board #1
    Board #2
    May 2016
    48
    Update: I found some time to test these and every channel on both boards work
    where the cold crisp winter weather winds nip at your noses and freezes your toe's es
    564
    Can you tell me what is the main difference between this REN 24 and one of Franks versions ? Is it the output power ? or ?
    8,973
    It's essentially the same capacity as Frank's board, unless you're comparing it to Frank's HC Ren24, which was his "high current' version. This uses the same BTA06 version of the triacs, the same MOC chips, essentially the same circuitry except this uses the big PIC instead of three 8-bit pics. The Renard-Plus boards can run either Renard or DMX, use start address, etc. They have an on-board ICSP header for reprogramming the PIC and an onboard Ren-W header for plugging a wireless gizmo directly onto the board. They work great.
    http://digwdf.com/store/
    The DIGWDF Store will be closing at the end of this year.
    While it's still open, please check us out for blinky-flashy gizmos that nobody else on the planet makes!
    564
    WOW... thank you for the info dirknerkle .. seems the PLUS boards have a BIG plus over the old REN 24's. GREAT price also ! ! ! !
    564
    Are these still available ?
    May 2016
    48
    Quote Originally Posted by JackFrost View Post
    Yes, they are still available
    May 2016
    48
    Both boards have been sold
