Results 1 to 10 of 11
Thread: what to do with leftover pixel strip
    Chesapeake, VA
    733
    Default what to do with leftover pixel strip
    Hello everyone. I moved last year and I'm in the early stages of re-designing a light display for this year. With that said. I want to ditch the pixel/rgb stips I used on my windows and roof line and use pixel strings (strips were a pain to keep up and repair). With that said. What should I do with the extra salvageable pixel strip? Anybody mixed and match strings and strips on the house? E.g. Stings on roofline, and strips on windows, etc? Did it look okay? Just trying to get ideas before I take the plunge on more strings. Thanks!
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
    Columbus, OH
    4,040
    Default Re: what to do with leftover pixel strip
    I think the best thing anyone can do with 'left over' pixel strips is to send them to me ~!
  3. Likes angus40, jaywalk101, tecnageek liked this post
  4. #3
    UK S80 postcode
    1,285
    Hi, you can make flood/wall washers from dumb RGB strips.
  5. #4
    2,820
    strips on arches and doorways. strings everyplace else.
  6. #5
    Kennesaw, GA
    880
    Sell them.
    Jim Nealand
    Kennesaw, Ga
  7. #6
    5,500
    Use them to make dual sided props as I have done .
    Encased in epoxy for ultimate water proofing .
  8. #7
    Chesapeake, VA
    733
    Good ideas. I think arches will probably be the best use. Ive just got so much of the stuff and a lot of it needs repair. Dumb rgb, ws2811, and lpd6803 strips. Hmmm. May also look into some pex tube for some driveway markers. I never can get these strips waterproofed all the way. Water always finds a way through the sleeve. Plus always seems like a led segment loses a color or the soldered bridges connecting the led segments shorts out. Ground level strips for now on! Lol
  9. #8
    Buellton, California
    237
    I gave most of mine away when I replaced house outline strip with C9 Pixabulbs. I couldn't charge someone for used strip. I hate strip... Will never use again and I couldn't sleep at night if I charged someone for it. I suppose I've given away or thrown away close to 1,000 feet of 30/10 strip. I'm over it, no place for it in my display. Did I mention I don't like strip?
  10. #9
    2,820
    Make a coat.
  11. #10
    Apr 2017
    3
    Put them on a fence?
