Results 11 to 20 of 26
Thread: HP DPS-800GB Power Supply Breakout Board
    Feb 2018
    9
    Default Re: HP DPS-800GB Power Supply Breakout Board
    Where do you find the printed circuit board? On the last parts you mention, do you have parts number so I can find these parts the websites.
    Columbus, OH
    4,057
    If you look in post number one at the bottom is the BOM and you will see that I also have PCPs for sale
    Quote Originally Posted by MrTeaIoT View Post
    Feb 2018
    9
    Have anyone try to run these with home 240v AC such as using Dryer plug for test? How long have this PSU use in the Server before retired them? I like to get one but afraid would not last long since pass their warranty time. How long can one of these last?
    Columbus, OH
    4,057
    10+ years is not an unreasonable expectation for expected life.
    The cooling fans are the item most likely to fail with age.
    Otherwise, they may very well last to be 15-20 years old.
    Afterall, how old are some other electrical items you own?
    Most are used in pristine conditions and are extremely well made.
    Most were used 4-6 years when retired.
    Mar 2015
    102
    It also depends where they were used. These are really high quality power supplies designed to be run 24/7 at pretty high loads. If it was used to its peak in a server room that is pretty dusty then they might not last as long, but if not I suspect they will last years in this hobby. Especially using this board design if one goes just unplug it and plug in the new one. As I posted above I actually drilled holes and soldered mine. I think these supplies are great and trust it to get a lot of use out of it.
    Feb 2018
    9
    Good to hear that. I will get a few and using the breakout board so I can swap them if needed. Have you test the maximum output of the power and how many pixels can it power? Does these small unit can actually produce the max of 850 watts power as specs? Why this unit use 0.3A on standby without any usage?
    Huntington Beach, CA
    137
    Feb 2018
    9
    Quote Originally Posted by tmcteer View Post
    It does not compatible with DPS-800gb power supply.
    137
    It works with the HP blue label 460W unit. I just called them and they confirmed which of their products with the power supplies I had. The were very responsive. YMMV
    T
    Columbus, OH
    4,057
    I suggest you get One and test it out.
    I don't have any real world experience with these for pixels yet.
