Results 1 to 7 of 7
Thread: A little advise needed
    Jan 2018
    North Wales, United Kingdom
    48
    Default A little advise needed
    Hi Guys
    ive attached a picture of a board setup that im hoping to do for Halloween, and im just wondering being new to all this, will it actually work?
    my idea of thinking
    the servo controller pca9685 will drive the servos which in turn will provide movement to my props
    the 74hc595 will give me the extra channels needed for the lights (5 lights for the props and 5 for atmospheric lights) i know i haven't included the right amount of relays/outputs but wanted to make sure before i went any further
    the relays ive used are set as singles and arent dimmable (something that i want) but couldn't find the right board in the software and the lights i will be using are dumb single colour led strips on 2 channels led spots on 2 channels an led strobe on 1 channel
    and for the prop lights probably cut length leds stips at 30cms
    thanks in advance
    Andy
    Jan 2018
    48
    Default Re: A little advise needed
    ok for some reason i cant post the picture will upload as soon as it will let me
    3,188
    Quote Originally Posted by Andsolo21 View Post
    You are missing the grounds going to the SSRs.
    Jan 2018
    48
    Oversight on my behalf, I was looking for an SSR Board (more than one) but there wasn’t one in the software so put them in for show and a general is it right, still looking to use that 12 channel ssr I pm’d you about the other day,
    Just wanted to see if I was ‘on track’ with my setup so to speak
    3,188
    yes you are on track
    Jan 2018
    48
    Fantastic thanks Martin, now it’s figuring out the code
    Jan 2018
    48
