Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Vixen, servos light etc
  1. #31
    Feb 2008
    Warminster, PA
    1,709
    Default Re: Vixen, servos light etc
    Quote Originally Posted by Andsolo21 View Post
    Hi Chris I’ve been looking at the jaw sequencer this evening on 2.1, seems to be going ok, as for the protocol, I haven’t received the board yet so I haven’t had chance to look into it in great detail but from what I’ve read it uses the i2c protocol and I’m guessing it can be used as a generic serial? Here’s the board
    https://www.adafruit.com/product/815
    I just want to make sure you have the right version of the addin. I think that jaw sequencer link had the old one. It should be this one. http://doityourselfchristmas.com/for...t=object+suite
    Chris
  2. #32
    Jan 2018
    North Wales, United Kingdom
    55
    thanks Chris
    currently downloading will look into it now
  3. #33
    Jan 2018
    55
    Brilliant bit of kit Chris, stuck in a dilemma now as I’ve got mixed sequences for Xmas and Halloween, Xmas I’ve done 4 so far in vixen 3 and I’m on my 3rd one in vixen 2.1 for Halloween
  4. #34
    Oct 2009
    Nelson (New Zealand)
    436
    I will add a big "Positive Plug" for Chris's plugin, it works brilliantly, even when imported into xLights for playout, see :- https://www.youtube.com/watch?v=wlbAJ2HyWiQ
    I used his Audacity conversion to get the mouth movement, all the rest was done "live", channel, by channel, watching the results on the prop during playback and making adjustments as required.
    Terry
    [B]"Tory Street Lights", Nelson, NZ[/B]
    [B]2013 - "Honourable Mention"[/B] - 2013 Local Christmas Lighting Competition
    [B]2013 :-[/B] 11 x Ren 64XC's - 650 Channels, 45,000+ lights. 7,000 or so LED's this year:-)
    [B]"Lucky Home" [/B]- 2012 Local Christmas Lighting Competition
    [B]2012 :-[/B] 11 x Ren 64XC's - 550 Channels, 40,000+ lights. 2,500 or so LED's for the first time :-)
    [B]2011:-[/B] 7 x Ren 64XC's - 384 Channels, 30,000+ lights - all incandescents! 2 x Commercial LED Panels (72x7)!
    [B]"Supreme Winner for 2010" [/B]Local Christmas Lighting Competition, 4 x Ren 64's - 256 Channels Controlled by Vixen - "Brilliant" :-)
    18,000 to 20,000 Lights - all incandescents! 2 x LedTricks Panels with "Pix C" interface's
    [B]2009:- [/B]128 Channels of "Hill 320", 4,000 Lights
  5. #35
    Feb 2008
    Warminster, PA
    1,709
    I don't use Vixen 3 but I believe you can import Vixen 2 into it. You might be able to use Vixen 2 for sequencing the servo stuff then import it into Vixen 3 to do the rest.
    Chris
  6. #36
    4,063
    Yes you can import V2 sequences into V3.
  7. #37
    Jan 2018
    55
    Thanks guys, great advice and guidance from all so far, really looking forward to getting things done for Halloween and Xmas
  8. #38
    4,063
    V3 has built in lip sync software that converts text to phenoms and then maps the phenoms to channels. You still need to manually sync the phenoms to the music.
  9. #39
    Jan 2018
    55
    Chris how do you get your levels to look like they do in your video? Mine are different fades and not vertical bars
  10. #40
    Feb 2008
    Warminster, PA
    1,709
    Chris
