Results 21 to 30 of 48
Thread: Vixen, servos light etc
    Palmdale CA
    144
    Default Re: Vixen, servos light etc
    have you checked out Chris /ctaml programs /adins /plugin he made for vixen 2.5 and halsatt Haunt Hackers website and you can do a search for 3 axis skull
    http://doityourselfchristmas.com/for...ght=axis+skull
    http://www.haunthackers.com/
    KEEP HI AND DRY
    Jan 2018
    North Wales, United Kingdom
    55
    Ok thanks Martin, Iíll give it a go
    Jan 2018
    55
    Thanks bob I’ll give it a look, is it compatible with vixen 3?
    Palmdale CA
    144
    I don't think so not at this time
    KEEP HI AND DRY
    4,564
    no i only wrote it for 2.x. i have not had time to port it to v3
    Feb 2008
    Warminster, PA
    1,712
    Depending on what you want to do you might want to consider using 2.x and the 3dObjectSuite. The only issue I can see is getting Vixen to talk to that server controller(I don't know the protocol it uses). If it's something that can use an available protocol it might save you some time.
    Here's some example of what I did years back....http://halloween.maloneylights.com/category/videos/
    Chris
    4,564
    I had been doing the color organ on 2.5 and then importing to V3
    Jan 2018
    55
    Hi Chris I’ve been looking at the jaw sequencer this evening on 2.1, seems to be going ok, as for the protocol, I haven’t received the board yet so I haven’t had chance to look into it in great detail but from what I’ve read it uses the i2c protocol and I’m guessing it can be used as a generic serial? Here’s the board
    https://www.adafruit.com/product/815
    Jan 2018
    55
    Forgive the ignorance, but what’s a colour organ?
    4,564
    Color organ is like a spectrum analyzer except it outputs the intensity to a light. Take the audio band and break it into three groups, Pass them through a filter and extract the peak intensity, convert the intensity into a light level. My implementation supports 32 bands (they can overlap) to drive the intensity value for 32 channels.
