Results 1 to 10 of 19
Thread: SS24 power issue
    Jan 2011
    Chili, NY
    44
    Default SS24 power issue
    Hoping someone can shed some light on my power issue with my ss24.
    Channel 1-12 output measuring 8vac, channels 13-24 measure 119vac on the neutral side. Power light is lit, nothing on the board leds though. The board was put together by a friend who decided not to go with blinky. Looks to be assembled correctly. Being a novice myself, this is way beyond my level of expertise.
    Serenity prayer for Xmas addicts:
    God, Grant my wife the serenity to accept the things she cannot change
    The courage to ignore my impulse purchases
    And the wisdom to know we need more lights
  2. Thanks jklingert thanked for this post
  3. #2
    Feb 2008
    Warminster, PA
    1,703
    Default Re: SS24 power issue
    Quote Originally Posted by flstc_93 View Post
    Can you upload some pictures of the board? Top and bottom.
    Chris
  4. #3
    Jan 2011
    Warren, NJ
    1,727
    You need to hook the ac power to two places on the ss24. Check to make sure you have power input on both ends of the board. Here is the troubleshooting guide http://www.doityourselfchristmas.com...he_Renard_SS24
    2012 Second Animated Christmas
    http://vimeo.com/33886466
    Tip: Backup your sequences on a free cloud storage site like Dropbox. Click Here for free 2Gb storage.
  5. #4
    Jan 2011
    Chili, NY
    44
    Power is connected to both ends and have 120VAC at the fuse. Went through the WIKI troubleshooting, maybe missed something, will go back through. Tried to upload pics, keeps error out. very puzzled by the 120VAC on the neutral side.
  6. #5
    975
    The neutral is just connected straight through. Why does that confuse you?
    where in the trouble shooting guide did the board fail?
  7. #6
    Jan 2011
    Chili, NY
    44
    Failed at step 13 I guess. Measures 10VDC @D3 & D4. Read the guide to indicate this was correct... It appears I'm wrong. So I need to try replacing the voltage regulator.??.. At least I have plenty of time to work through this...
  8. #7
    Mooresville, NC
    7,466
    Do you have 4.8 - 5.0 volts at the test points?
  9. #8
    Jan 2011
    Chili, NY
    44
    4.73VDC @ +5
    1.93VDC @ right side R6
    4.72VDC @ Left side R6
    7.76VDC @ D3, D4
    4.24VAC @ R1,R2
    119VAC @ Top, Bottom F1
  10. #9
    Mooresville, NC
    7,466
    If everything is installed correctly, I think I would start with a reflow of all of the solder joints. Some of the voltages are out of range.
    Try to take a good (large) picture top and bottom to post.
  11. #10
    Jan 2011
    Chili, NY
    44
