Results 1 to 10 of 16
Thread: Permanent portable hole
    Sep 2013
    Seattle, WA
    1,093
    Default Permanent portable hole
    I've now gone 5 years with the Monkhouse Portable hole.
    It has served me well, but time to move up. Or... down, in this case. I'd like to have a permanent cement structure about 6 foot down into the ground which I can just screw a pole into each year.
    Obviously I can just extend the Monkhouse flange-based structure 6 feet deep, but I was wondering if there is a better way. I don't want an IMC flange sticking out but rather something that has 4 bolts that I can tie any kind of base into during the season, and then have it under-ground and covered with an irrigation cover for the rest of the year. I know Rohn towers do things like that but I really have no experience with them.
    Second to that, I would prefer if it has a base with a counter-balance on the pole, so that I can just tilt the pole over with the star and strands already on it. So something like this:
    but ... not that exact one since it weighs 450 lbs...
    Has anybody done something like this with a MegaTree? Or just general tips with permanent bases? e.g. How do you level a pole in a permanent base? (Washers?)
    2017: 33069 pixels, 24 E682's. 50 A/C with 2 LOR
    2016: 21500 pixels, 24 E682's. 6 A/C with 2 LOR
    2015: 7500 pixels, 11 E682's. 35 A/C with 3 LOR
    Columbus, OH
    4,138
    Default Re: Permanent portable hole
    How tall of a tree?
    I simply buried a PVC pipe in concrete, like you would a fence post, 3 feet deep. THAT will never pull out or go sideways. I have a simple screw on cap at ground level. The lawn covers it in short order and sometimes I have to search for it in late fall.
    I've done this at two houses now with equal success.
    2,385
    We have a couple here. (3 feet into the ground, to get them below frost level and prevent them from being pushed up.)
    We put caps on them during the year (keeps them from filling up with gunk from the yard). Knowing where they are when it comes time to put up the display is a plus. Grass spreads out onto them each year.
    5,687
    Columbus, OH
    4,138
    Exactly! Just match the plastic pipe inside diameter to your steel pole.
    Feb 2017
    253
    I posted my mega tree hole a few months ago which has a few pictures of pouring concrete in the ground for a permanent hole. If I remember right I used a 2" PVC pipe in the ground because it fit a 1 1/2" ridged pipe really well. I then welded on an adapter so the 1 1/2" pipe screws onto my 2" ridged pipe for the main mega tree pole. It's very sturdy and I can put a ladder against it even with out the guide wires on it. It worked really well. It's very sturdy, was easy to build and sets up fast. If you ever change your mind just cut off the PVC level with the concrete and cover it with dirt. No one will ever find it unless they want to plant a tree there some day, then it's their problem! LOL.
    Im going to use the hole for a temporary flag pole this summer for the forth of July and Memorial day.
    http://doityourselfchristmas.com/for...Mega-Tree-Pole
    Dale P.
    Sep 2013
    Seattle, WA
    1,093
    Interesting. So is this PVC pipe idea effectively just a friction and gravity fit and you drop the Ridged pipe in there?
    7,576
    Quote Originally Posted by deonb View Post
    Yep. Iíve seen many residential flagpoles mounted this way. Including mine
    Columbus, OH
    4,138
    Exactly.
    I've done it for years. Works great. Very inexpensive and very secure.
    Shelby Township MI
    274
    Frost lines vary from state to state, Michigan is 42", but make sure you hit your frost line depth for sure.
