Results 11 to 20 of 22
Thread: Mounting a big (56 panels) P10 Matrix to windows
    78
    Default Re: Mounting a big (56 panels) P10 Matrix to windows
    yeah, now that I sat and looked at it all it may be closer to 40 pounds, each panel is about 1/4lb so 50 panels is 25 pounds, maybe another 5 pounds in power supply, wires etc... and a few more pounds in the materials to build the frame
    Oct 2009
    709
    My 30 panel matrix has to weight at least 45 lbs.
    The red circles for the hooks would have to be screwed into the window headers to ensure a solid anchor.
    The other questions is how would you get that up there. Certainly not using a ladder with something that size and weight.
    P10's are the only way to go for the project you want to build.
    Video will look fantastic and the color range and brightness cant be beat.
    78
    yeah I definitely need to hit headers, I may have a contractor come by once it warms up and do it for me so I know its in good and then I will have to figure out how I get this on the window each year, was thinking 2 guys, 2 ladders, climb up and hook on like a picture
    Oct 2009
    709
    Your braver than I am. But something that size will be impressive.
    You might consider aluminum products like these
    https://m.alibaba.com/product/607217...76d36aaaFu5Ga5
    which are built for P10 displays. But someone on the forum - JCook I think - had problems with the product arriving damaged.
    These would be nice because they are so much light than wood.
    78
    I like those, im assuming the grooves are cut to fit in the hardware like boscoyostudios p10 pieces that we use to connect panels together?
    Oct 2009
    709
    Yes and the small groove would be for the plexiglass. I really want to give them a try.
    78
    hmmmmmm I may order some, I like this idea, then I just need 2 long wood supports on both side in back to really support the weights, I doubt I can hang this by the aluminum
    78
    plus I would clear vinyl wrap the front vs heavy plexiglass
    78
    wound up being 54 panels, and 6 wide by 9 tall, I love the way this looks. Going to run sume 1x3's up the back for support and then wrap it in 3M protector. cant wait for the warmer weather so I can start to plan the mounting part
    here are 2 videos I shot quick
    https://youtu.be/6rQnLUIDsZs
    https://youtu.be/mTV4Xw1EVKQ
    Oct 2009
    709
    Awesome - plain awesome.
