Results 11 to 17 of 17
Thread: Pixel Icicles
    Dec 2018
    3
    Default Re: Pixel Icicles
    Quote Originally Posted by astrosnapper View Post
    I have run scrolling text on mine using the 6x6 font in xlights, it looks pretty good and is readable.
    SOLD! Thanks!
    Goleta, CA
    8
    I have uploaded a video of some scrolling text running across my set of icicles (which are mounted to a piece of 1/2inch EMT with 3 90 connectors at each end and hooked over a wall at the edge of the house) to my YouTube channel. This used the "6x6 Thin" font in Xlights with 'left' movement and speed=3. Some of the pixels are slightly blocked off by parts of a Bird of Paradise plant in the foreground which is just right of center...
    Dec 2009
    Pedleton Kentucky (near Louisville)
    286
    I have 9 sets across my roofline. They were new this year , I really like them and the effects are great. the only thing about them is they are a bit tidious to set up in the display in Vixen because they are 3,4,5 lights at 15 strings.
    I finally numbered them strand 1- 1,2,3 , Strand 2-1,2,3,4 , Strand 3,- 1,2,3,4,5 etc. to keep them all straight. Being 3,4,5, I couldn't get the graphics or text to work correctly 3 pixels doesn't give you any letter or number that looks right..
    You can check them out at our website below !
    See all our videos at:
    http://www.hickoryhollow74.wix.com/hickory-hollow
    Vixen 3.5
    "Electrical Tape is my Friend"
    Falcon F16V3
    Renard SS24 (8)
    20 Universes
    25,000 + lights
    Dec 2018
    3
    How is the data run back to the 'main' run from the end of drop? Do they run 4 core on the drops? Do they attach an extra wire?
    My concern is, will I be able to shorten or lengthen the string, if need be, to fit my house?
    SF CA
    562
    Quote Originally Posted by HSSUSC View Post
    Generally yes, the data OUT (at the end of each icicle) need to be run up to the top (of each icicle), so that the data can cascade to the next icicle. Some icicles may actually have this return-line built into the strip. Others may simply run a single wire back up to the top.
    Dec 2009
    286
    The strings your looking at from Ray are 3-wire on the main run but have a forth wire along each drop to the next string.
    They have a pre-wired connector on each end but they can be trimmed. I had to trim a short length off one of the strings .
    I used tees every other string for power injection and also injected at the end . No issues.
    Vixen 3.5
    Falcon F16V3
    Renard SS24 (8)
    20 Universes
    25,000 + lights
    Dec 2009
    286
    Also, I used mounting strips from Boscoyo so you can vary the width a bit. The come I believe 8 inches between drops but I shortened to 5 with the strips.
    Vixen 3.5
    Falcon F16V3
    Renard SS24 (8)
    20 Universes
    25,000 + lights
