Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Mega 2560 and Vixen 2.1 SSR relays flicker when vixen runs
    11
    Default Mega 2560 and Vixen 2.1 SSR relays flicker when vixen runs
    ok, so with my Mega 2560 and Vixen 2.1 on the computer the SSR relays flicker when vixen runs, they are all on if vixen is off, and when started they work as they should however they all flicker like a strobe constantly until vixen shuts off, then they go back to full on again. what could be my issue.?
    I think this is the code im using, its the only one i can find so it must be:
    Allow Vixen to control Arduino MEGA outputs.
    To control 16 relay channels. RELAY1, RELAY2, etc are the relay control pins.
    This version was tested with Vixen 3.
    Also eliminated the footer feature. This version only uses a header "~!"
    in Vixen 3. In Vixen don't use the quotes, just the two characters.
    While Vixen 3 is sending data, the Arduino RX light is ON.
    // pinouts used.
    #define RELAY1 2
    #define RELAY2 3
    #define RELAY3 4
    #define RELAY4 5
    #define RELAY5 6
    #define RELAY6 7
    #define RELAY7 8
    #define RELAY8 9
    #define RELAY9 10
    #define RELAY10 11
    #define RELAY11 12
    #define RELAY12 13
    #define RELAY13 14 /44
    #define RELAY14 15 //45
    #define RELAY15 16 //46
    #define RELAY16 17 //47
    // Configure outputs
    int chanDigital[] = {RELAY1, RELAY2, RELAY3, RELAY4, RELAY5, RELAY6, RELAY7, RELAY8, RELAY9, RELAY10, RELAY11, RELAY12, RELAY13, RELAY14, RELAY15, RELAY16};
    int vixByte[16]; // size of the channel array
    int chanDigitalCount = 16; // Total number of ON/OFF channels.
    int i = 0; // Loop counter
    //setup the pins/ inputs & outputs
    void setup(){
    // initalize digital Channel Pins as outputs.
    for (i=0; i < chanDigitalCount; i++){
    pinMode(chanDigital[i], OUTPUT);
    vixByte[i] = 0; //set array at 255 not 0 for relay OFF by inverting. only if mech relays used. but im using ssr so leave at 0
    analogWrite(chanDigital[i], vixByte[i]); //use either analog or digitalwrite
    //setup Vixen USB serial port.
    Serial.begin(9600);
    void loop()
    if (Serial.available() >= chanDigitalCount+1) {
    // changed +2 to +1 in above line to have correct channels on relay board
    //int uno = Serial.read();
    //if (uno == 126){
    //int dos = Serial.read();
    //if (dos == 33){
    // We are now past the header so read and send the 16 channel data.
    for (int i=0; i<16; i++) {
    // read each byte
    vixByte[i] = Serial.read();
    analogWrite(chanDigital[i], 0 + vixByte[i]); //Send to relay pin. use either analog or digitalwrite
    //} //end of loop
    Nov 2009
    Morrisburg, On, Canada
    2,540
    Default Re: Mega 2560 and Vixen 2.1 SSR relays flicker when vixen runs
    Hard to say. It sounds like you have no synchronization between Vixen and your Arduino.
    Did you use the header ~! in your Generic Serial setup?
    Is your baudrate 9600 in Vixen?
    You should use digitalWrite for zero-cross SSRs.
    Edit:
    Also, some SSR relays use inverted logic so you may want to verify what your relays need.
    Southern California
    825
    Quote Originally Posted by thecanadiandaily View Post
    // pinouts used.
    #define RELAY1 2
    #define RELAY2 3
    #define RELAY3 4
    #define RELAY4 5
    #define RELAY5 6
    #define RELAY6 7
    #define RELAY7 8
    #define RELAY8 9
    #define RELAY9 10
    #define RELAY10 11
    #define RELAY11 12
    #define RELAY12 13
    void setup(){
    Serial.begin(9600);
    void loop()
    //if (uno == 126){
    //if (dos == 33){
    // read each byte
    //} //end of loop
    This code was designed to use a header of two characters. That is probably why it checks for serial available +2. You have the header test commented out, so it is not testing for those two characters but the serial available is still lookig for the channel count +1. So the data stream does not look like it is syncing up.
    You should un-comment the lines in blue above and change the serial available test back to +2 and make sure you have the header setup in Vixen controller.. Or you could try the code by Victor_PV found here - http://doityourselfchristmas.com/for...th-Random-mode
    Kevin
    Oct 2017
    Davis, California
    26
    Also, missing one of the slashes in the comment of this line:
    Although, I'm not sure that would cause the problems you're describing, it may cause problems assigning that pin.
    11
    yeah i fixed that, makes no difference
    11
    no idea what you mean about the headers ! and iam using vixen 3.2 i thought iwas using 2.1 but no.
    11
    update to my issues here: i am using vixen 3.2, i tried also a windows 7 computer its still the same, my board is a 2560 mega sainsmart, and the relays are also sainsmart SSR's .
    Kevin above talks about headers ?? no idea what that is.
    I made changes as per above but now nothing works, no relay movement, here is the code so far:
    // pinouts used.
    #define RELAY1 2
    #define RELAY2 3
    #define RELAY3 4
    #define RELAY4 5
    #define RELAY5 6
    #define RELAY6 7
    #define RELAY7 8
    #define RELAY8 9
    #define RELAY9 10
    #define RELAY10 11
    #define RELAY11 12
    #define RELAY12 13
    #define RELAY13 14 //44
    void setup(){
    digitalWrite(chanDigital[i], vixByte[i]); //use either analog or digitalwrite
    Serial.begin(9600);
    void loop()
    if (uno == 126){
    if (dos == 33){
    // read each byte
    digitalWrite(chanDigital[i], 0 + vixByte[i]); //Send to relay pin. use either analog or digitalwrite
    //end of loop
    Nov 2009
    2,540
    You add the headers in Vixen in the Generic Serial setup where it has a place for HEADERs and FOOTERs.
    11
    sorry man i still have no idea what to add there. whats a header? im too new to this.
    11
    this code here you directed me to by Victor_PV does not work at all, it random flashes and vixen does not even do anything with it.
