Results 1 to 10 of 12
Thread: XLights Odd Problem - need help
    135
    Default XLights Odd Problem - need help
    I am running xlights and have 4 vertical columns setup as matrix's. 2 of them work perfectly, the 3rd one has an interesting problem (4th i am building today). It is 54 pixels high with 4 rows.
    When say doing a test sequence for the entire house in red, everything goes red except for the last 48 or so pixels in the 3rd column. They go green. I know control works because they will all turn white, or if the house blue they go red. I thought maybe it was a splice point where a new strand starts but it was the middle of a strand.
    I have narrowed the problem down to xlights, at least i think. I came to this conclusion because if I run test patterns from the controller itself (e6804 from san devices) the matrix all turns to the same color.
    I also tried cutting where the issue starts and removing the last correct pixel and connecting a new strand, but the problem is the same.
    I am using RGB ws2811 square nodes from Holiday Coro.
    Thanks!
    Winter Haven Florida
    3,039
    Default Re: XLights Odd Problem - need help
    can you post a screen shot of your setup page in xlights
    James WinterHaven Fl
    Jun 2011
    1,882
    Could be a few things.. model setup.. or possibly a render issue. Sounds like you have them doing a variant of RGB or a channels is missing somewhere. Are you testing in the "test" section or running a sequence when you have the issue?
    Jul 2015
    342
    My guest is it is a mismatch between the universe size in XLights and the controller. Maybe 510 vs 512.
  5. Likes plasmadrive, TazChaLet liked this post
  6. #5
    135
  7. #6
    135
    Quote Originally Posted by keithsw1111 View Post
    You are correct my friend! Should they be set to 510 or 512? 510 seemed to fix this fixure.
  8. #7
    Jul 2015
    342
    Some controllers only support 510. Others are happy to use 512. What is important is they match.
  9. #8
    168
    sandevices uses 510
  10. #9
    135
    yup, this was the issue for sure. Now that i have them all set to 510 other odd problems are fixed that i thought was my sequencing or something. Thanks!
    new this year to x lights.
  11. Likes TazChaLet liked this post
  12. #10
    3,039
    I had a feeling it was the 510/512 in xlights causing the problem I had a similar problem when I got my 682
