Results 1 to 10 of 14
Thread: Simple antenna for transmitter
    Dec 2015
    Saint Louis
    110
    Default Simple antenna for transmitter
    Hi everyone
    I need to add a simple antenna to this transmitter:
    From what I understand, a short length of wire should work fine. I only need to go about 35 feet from the front of my house to the street. Any advice?
    Ken
    Columbus, OH
    4,020
    Default Re: Simple antenna for transmitter
    start with a 16" piece of wire and see how it does !
    Nov 2017
    39
    For anyone that has done this, I have the same kind of module. Does it matter what kind or gauge of wire you use? And do you just solder it on?
    41
    I used a 23AWG strand of wire about 30 inches long (a piece of a Cat5 cable I cut up). Just soldered it into the hole marked "ANT". Works great out to my front yard and driveway...haven't tested max distance yet (because I'm having sync issues with my lights still).
  5. Likes Ruppro liked this post
  6. #5
    Nov 2017
    39
    Quote Originally Posted by DaveCorder View Post
    Thank you for that, I'll do the same then. And the board can be powered by the USB port right? At work and haven't had a chance to test it out yet.
  7. #6
    41
    Quote Originally Posted by darko886 View Post
    Yeah, powered from USB and shows up as a USB sound card. Even remembers the set frequency when unplugged and plugged back in.
    Sent from my Pixel 2 XL using Tapatalk
  8. #7
    Nov 2017
    39
    Excellent
  9. #8
    Yuma, AZ
    1,596
    Hi:
    Where did you obtain the transmitter?
    Even though my little FM01 is working great ( over 1/2 mile on a dipole ant inside a building) I am always interested in other lower devices.
    Idun
    http://www.vixenlights.com/sig/sig_h.php/152/136.gif
    Lotsa' Patience! (Some days you can't win, the others you lose, and forget about the rest)
    Some mornings I wake up GRUMPY and other days I let her sleep!
  10. #9
    Columbus, OH
    4,020
    +1 on the FM01 !!
    Quote Originally Posted by IdunBenhad View Post
    Hi:
  11. #10
    Nov 2017
    39
    Hi:
    I got it from a member of this forum but you can search PLL FM transmitter in eBay and see a bunch of them.
