Results 1 to 8 of 8
Thread: String son E682 cloning
    356
    Default String son E682 cloning
    SO here is my issue, string 2 and string 3 on my mega tree are cloning each other. If i chose node 100, which should be the bottom node on string two, node 101 on string will light up. Does this for all nodes on those two strings only. I have all my strings zig zagging. 100 nodes per output. Here is my setup....
    Jan 2010
    Bartlett, TN
    122
    Default Re: String son E682 cloning
    Do you have the channels per universe set the same in the controller and whatever software you are using to control the lights? You can use 510 or 512 channels per universe but it needs to be set the same in both places.
    356
    Quote Originally Posted by scott4864 View Post
    Yes, ,something is very wrong, i was trying light up pixel number 351, ,that would be the first pixel on string 8, but it would not turn on. There were no issues when i had it running these same trings off the same ports on the mega matrix back during halloween. I think i may try and reinstal the firmware and wee what happens.
    Jan 2010
    Bartlett, TN
    122
    What are you using to test it? xLights, FPP test page, etc... What does it do when you run the test built in to the controller?
    356
    I have tried testing with xlights and FPP, the tester on the UI page works correctly, but i can not test individual channels with it.
    356
    SO this is what my tree does in test mode. Will eventually right itself.
    https://www.facebook.com/jerry.c.tho...0095014316775/https://www.facebook.com/jerry.c.tho...0095014316775/
    West Bloomfield, MI
    572
    Quote Originally Posted by jerry72 View Post
    You can test individual channels in FPP. Just put the correct contiguous channel range in boxes near the top. I doubt if your issue is firmware. You have a set up problem in either Xlights or FPP. Your E682 looks right.
    Ed
    Happily retired
    Kansas City Missouri
    1,933
    On the FPP player page you can test individual channels. Just under "Enable Test Mode" there is " Channel Test Range". I'm not familiar with Xlights but I'm sure you can test individual channels. Go to "Tools, test" and the channels are listed. To activate just a channel double click on the box next to the listed channel. To test all channels double click on the box next to the controller listed.
