Results 31 to 35 of 35
Thread: Sketch to keep lights lit when no in sequence?
  1. #31
    2,890
    Default Re: Sketch to keep lights lit when no in sequence?
    Here is a bit of info on frame capacity. I am using the common baudrate of 57600 bits per second.
    1 byte takes 1 start bit + 8 data bits + 2 stop bits (worst case) = 11 bits for one byte of data
    57600 / 11 = 5236 bytes per second
    A frame rate of 25ms = 1 / 0.025 = 40 frames per second
    5236 / 40 = 130 bytes per frame.
    Since one channel uses one byte of data, you get 130 channels per frame. The practical limit is a bit lower than this. If you work with 100 channels per frame then you should have no issues.
  2. #32
    Nov 2017
    39
    Very well broken down, thank you. The person who showed me how to build my controller advised to set the baud rate to 9600. Is there any reason why I would set it that low, or should I change it to 57600? I am running an Arduino Mega 2560 with two 8 channel SSRs.
  3. #33
    Morrisburg, On, Canada
    2,502
    Quote Originally Posted by darko886 View Post
    The reason you would set it to a certain baudrate is to ensure that a microprocessor has enough time to do other things. So if 9600 baud allows you to view your display in sync with Vixen sequence without flicker then that's all you care about. Sending it faster will give more time between frame rates. As you add more pixels then more time is spent updating those pixels. Hence the need for faster updates to keep a minimum display refresh rate to avoid flicker.
  4. #34
    2,890
    There are pros and cons to the lower baudrate:
    • Lower baudrate allows you to use lower capacity (AKA Cheaper) CPUs. The AT-MEGA line is not a very powerful CPU but it is not in the severely underpowered category. It should handle 56K. Especially if you are only sending 16 bytes of data.
    • Lower baudrate carries fewer channels.
    • Lower baudrate has higher latency. Does not matter because mechanical relays are very slow.
    • Lower baudrate is horrible for dimming (mechanical relays cannot dim so this does not matter to you).
    Higher baudrate is not needed because relays cannot keep up with a 25ms frame anyway. Most relays will have difficulty keeping up with a 100ms frame rate and they are best used to just turn things on and off over long (multiple seconds) periods.
  5. #35
    Nov 2017
    39
    Thank you guys!
