Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: RGB LED Rope lights
    Sep 2007
    Iowa
    447
    Default Re: RGB LED Rope lights
    I found some better pictures as well..
    -Craig
    Sep 2017
    32
    Thank you for all the replies and suggestions. I looked at the neon pixel strips and although it would work fine for a wire frame setup I'm not convinced it is true 360 degree visible. Unfortunately the setup I'm using is not static and will need the all round visibility. Looks like I would have to do some experimenting in the direction that Craig mentioned.
    3
    dmx rgb led light
