Results 1 to 10 of 10
Thread: I must be doing something wrong
    Oct 2009
    734
    Default I must be doing something wrong
    I am finally getting back into video mapping using Adobe After Effects. Heres an image of my house front that is being used for the masks.
    This is only a learning project so please don't judge.
    The masks were created on the "house image"
    You can see from the photo the images (video actually) are being show in the masked areas.
    But somewhere I am lost with the work flow.
    Once a project is completed do I render this as a movie to project?
    If so the movie has my house in it - that doesn't sound right - or am I supposed to project the image of the house onto the house with the content?
    Shouldn't I just have a mask layer with the content.
    Maybe I am creating the masks incorrectly. Any help would be appreciated.
    Covewi
    6,466
    Default Re: I must be doing something wrong
    Hide the house layer before you render !
    Oct 2009
    734
    That was just too easy - but makes sense!
    Oct 2009
    734
    Hiding the house reveal this. Which does not look correct.
    Heres without the video content hidden.
    And with the content.
    Something is wrong with the masking process I would bet
    6,466
    Definitely masking process issue .
    Oct 2009
    734
    Tried this:
    layer #3 Solid layer < adjust transparency to 50 % or less , now create a mask and apply effects < when done restore transparency to 100%
    layer #2 Solid layer < adjust transparency to 50 % or less , now create a mask and apply effects < when done restore transparency to 100%
    layer #1 house < keep on the bottom < hide before render .
    This mask appears to work correctly
    Here I added another layer and content
    Heres the second mask
    This is what I get - but can't see the layer content thats below.
    Oct 2009
    734
    More on the previous post.
    Then how would I add masks to that the window would show through the content? I added another mask to the first layer but the window don't show through.
    Oct 2009
    734
    Does this look correct - I am using alpha effect on the layers.
    Oct 2009
    734
    Thanks for your help - everything is coming back after "playing" around with AE for a while.
    I do have one problem. After taking the house photo - form where the projector will be and setting the AE composition to that of the projector - I imported the house photo into AE.
    The photo is much larger than the composition window so it needs to be scaled. Do I manually adjust the size (by grabbing the adjust edges) of the photo so it fills the composition windows?
    6,466
    In Ae select the image then click > layer\transform you will see fit to comp variables .
