Results 1 to 10 of 20
Thread: AC lights tripping GFCI when it rains.
    Dec 2015
    Saint Louis
    194
    Default AC lights tripping GFCI when it rains.
    Hi everyone,
    I am having an issue with my lights tripping the GFCI when it rains. I have electrical tape over all open connectors (like on the back of the male plug of a mini light set) but I have not totally taped each connection 100%.
    I assume water is getting in one of these connections.
    I used to wrap all connections in a plastic sandwich bag and then tape the bag shut, but I quit doing that a couple of years ago.
    What do you all do to avoid this problem?
    Ken
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
    Palm Bay, FL
    695
    Default Re: AC lights tripping GFCI when it rains.
    I put a dab of dielectric grease on the connections that I know are in wet areas.
    1,530
    Keep them off the ground. If you are using Tomato cages, or something similar, for mini trees, that are metal, make sure they do not sit directly on the ground.
  4. Likes jklingert liked this post
  5. #4
    Dec 2015
    Saint Louis
    194
    Shouldn't I be able to figure out which string is tripping the GFCI by turning on each one separately until it trips?
  6. #5
    Maryville, TN
    257
    Take the tape off the light string connectors. Leave them open to the air so any water can drain out. They are made that way.
    Yes, keep them off the ground. elevate them slightly on something not conductive like wood. another option is add a tent over the connectors.
    My first year I did the tape thing and when taking to display down, all the tapes connectors had water, mold and rust, never did it again.
    Inventor of the "LED Keeper"
    My Videos [URL="http://www.vimeo.com/Dennischerry"]www.vimeo.com/Dennischerry[/URL]
  7. Likes critic2 liked this post
  8. #6
    4,298
    That is one experiment. This experiment makes an assumption that may not be true: "A single set of cords is causing the issue". You might be getting leakage through a combination of cords connected to the GFCI.
  9. #7
    South Weber UT
    448
    When I had this problem it was always leakage from the light stands themselves being wrapped around a metal object and staked securely to the ground. I added a plastic “spacer” so the metal support wasn’t grounded and the trips went away.
  10. #8
    Nov 2012
    Cary, NC, US
    1,221
    At least you know GFCI is doing its job
  11. #9
    Pedleton Kentucky (near Louisville)
    285
    I take a small dab of silicone sealant and put it at the base of the male connector then plug them together.
    Then keep them off the ground.
    It just pulls apart at the end of the season. Also check the AC power cords, I found a small nick in the insulation
    that was causing a grounding problem.
    See all our videos at:
    http://www.hickoryhollow74.wix.com/hickory-hollow
    Vixen 3.5
    "Electrical Tape is my Friend"
    Falcon F16V3
    Renard SS24 (8)
    20 Universes
    25,000 + lights
  12. #10
    Delaware, OH
    4,389
    I fixed my issues by wrapping plastic around the bottom of my metal mini trees and I only use plastic tent stakes for hold downs of objects.
    No issues in my very wet environment.
