Results 1 to 10 of 29
Thread: Free xlights sequences
    7
    Default Free xlights sequences
    Does anybody know a good repository for free xlights sequences and other stuff?
    Sep 2016
    Long Island, NY
    21
    Default Re: Free xlights sequences
    You can find some here on the xLights share drive
    https://drive.google.com/drive/folde...UVzX0ZMc1pzY00
    7
    Nice. I will try them
    Nov 2017
    1
    Jul 2015
    409
    Or in the tools menu.
    Huntington Beach, CA
    62
    Any chance we'll be seeing more from Logan Carpenter this year? (SWOWLI) His sequences are definitely the highlight of my display!
    32
    Anybody know the password when unzipping the files? Thanks
    Feb 2016
    Somers point nj
    431
    Xlights
    Oct 2009
    783
    Once downloaded - besides the mp3 file there are XML files - do I open those in xLights or do I have to convert them to a fseq file some how?
    How do I know what models to build?
    Any help would be appreciated.
    Aug 2012
    Nova Scotia, Canada
    1,910
    Xlights makes this so easy for you to see the sequence as the original uploader had it programmed.
    1. Unzip sequence onto hard drive
    2. Open Xlights and change your show directory to whatever directory you unzipped the sequence. (make sure to select the directory where the xlights_networks.xml and xlights_rgbeffects.xml are located).
    3. Once that is done you can see models and house preview that original sequencer has.
    4. Now open the sequence (actual .xml file of sequence) and watch how it plays on house preview.
    5. After watching a few times decide how each model would look mapped onto your models. (ie. you have pixel mini trees and original has them, or map stars to snowflakes whatever).
    6. Now switch your show directory back to your original location and create a new sequence using the correct MP3 file.
    7. Select IMPORT and then IMPORT EFFECTS. Map the sequence models to yours and that is it.
    Render it and save.
    Play it and see how it looks, you can always re-map models to other models at any time by doing another import. (careful though as you will overwrite effects if on same model).
