Thread: Power injection testing . Surprising what little is needed .
    6,219
    Default Power injection testing . Surprising what little is needed .
    This is my first time ever adding/attempting power injection .
    Using 10% output , here is 6 pixels shy of 3 universes with 1 injection @ pixel 504 .
    @ full white there is very minimal heat transfer though increasing to 20% output the heat does get noticeable .
    I can certainly imagine how folks were losing strip to melt down if running @ 100% .
    Just thought I would share with those thinking on using strip but worried about heat and strip loss .
    Have no fear if you have the right controller .
    In my case testing , its the HinksPix16 now sold as the Easylights Pixel controller found here
    Sep 2017
    16
    Hello Angus,
    Looks great Iím looking into make a Pixel matrix with a top Round form.
    Iím between using
    12 mm pixel or
    LED strip with 30 pixels per meter as the below pictures shows.
    If I go with the LED strip i will have more pixel density, either of this 2 options I will need to do power injections.
    So I wanted to ask you for which one of this w options do you think will work better.
    And how Can I make this possible to control in vixen ? I was planning to install them vertical so I can have all the connections coming from below the matrix, but my question is since I have the top part of my Matrix curved if I will encounter any problems trying to display a right picture, what do you think in your experience?
    Iím all new in this so I just want to approach it the best way possible.
    Thank you!
    6,219
    Default Re: Power injection testing . Surprising what little is needed .
    Hi Rulos
    That window is a great shape for a very cool matrix .
    You may want to view some of the various pixel matrix videos on you tube to get a better feel for what your preference may be .
    Still experimenting with matrix elements myself , so really can't say which is a better choice .
    If using Vixen , you may want to pop into the Vixen forum and post a thread for matrix setup and the how to's .
    Unfortunately I am not much help there as I have not used Vixen .
    I look forward to following your build though and thanks for posting .
