Results 11 to 20 of 33
Thread: scheduler crashes vixen 3.4u2
    Gaithersburg, MD
    225
    Default Scheduler crashes vixen 3.4u3 508
    Quote Originally Posted by PCPackrat View Post
    Me too... Running derv build #510 and its loading again for me. Thanks,
    Hi all, just d/l 3.4u3 build 508 and I am crashing - where to get 510?
    11/30/2017 14:38:12.718 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
    at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
    at VixenModules.App.SuperScheduler.ScheduleItem.get_N extStartDateTime()
    at VixenModules.App.SuperScheduler.ScheduleExecutor.< UpNext>b__1(ScheduleItem x)
    at System.Linq.Enumerable.WhereListIterator`1.MoveNex t()
    at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
    at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__ 1.MoveNext()
    at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
    at VixenModules.App.SuperScheduler.ScheduleExecutor.P rocessTimerInUIThread() at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
    11/30/2017 14:40:06.197 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    2016 Migrating to Vixen 3.2
    Vixen 2.5x
    120 Channels
    2015 5 RenardSS24 @ 20,600 lights
    2014 5 RenardSS24 @ 18,600 lights
    2013 3 RenardSS24 @ 9,900 lights
    2012 2 RenardSS24 @ 6,000 lights
    2011 began researching
    [url]www.KentlandsChristmas.com[/url]
    Gaithersburg, MD
    225
    Default Re: scheduler crashes vixen 3.4u2
    ahhhhh- build 510 allows me to schedule, again.
    Vixen 2.5x
    120 Channels
    Oct 2017
    Davis, California
    26
    What's the proper way to install these dev builds? I don't see the typical setup.
    Thanks!
    Feb 2008
    Marietta, GA
    542
    I have 510 running now and a show is up (daytime inflatables) with the real show scheduled to start at 5:30. I will check it at 11 when it stops to confirm the fix. Thanks DEVS!!!
    Making it bright since 1989...
    Feb 2008
    Marietta, GA
    542
    Quote Originally Posted by bkcoughlin View Post
    Thanks!
    Just run the .exe installer from the download site. It will be the usual Vixen install except it will install the program into a new folder (Vixen Development) under Program Files rather than the default Vixen folder. The DEV version will still look for Profiles in your Documents folder so nothing else should change for you.
    I like to live on the edge so I changed the install folder to Vixen so the install replaced my old version with the DEV version. Since I knew this was a patch release I was not too worried about breaking anything.
    When you launch the program it should read your profiles and pull your settings just like the other version and look exactly the same to you except a pop-up warning it is a DEV version.
    Cheers!
    Oct 2017
    Buchanan, GA
    325
    Developement build #510 is now available that should resolve this issue. This is a patch on top of the 3.4u3 release and can be found in the development builds download section on the Vixenlights web site. This should also resolve the issue of the up next showing tomorrow for the next show when it should really be today.
    Edit: I found the file im downloading it now i went to open my program to make a new sequence and all 3 windows pop open then right back shut i didn't know what was going on... its funny cause i feel sleep lastnight and left the pc open then today it wont open
    Oct 2017
    Buchanan, GA
    325
    okay so i installed it but now when i go to open it it pops up and says windows can not access the specified device,path,or file you may not have permissions to access the item
    FB @ langleylights
    Oct 2017
    Davis, California
    26
    Quote Originally Posted by scottmcm View Post
    Just run the .exe installer...
    Got ya.. thanks! I pulled from the GitHub site.. didn't realize there was another repository of EXEs.
    Oct 2017
    Buchanan, GA
    325
    Well it seems my AVG thought the file was harmful and wasn't letting it install as it should. i had to stop it and uninstall and re install it seems to be working now.
    Feb 2008
    Marietta, GA
    542
    I just got home again and it looks like the daytime show transitioned to the night time show properly. Looking good!
