Results 1 to 8 of 8
Thread: Serial port closing after first sequence.
    Calgary, Canada
    28
    Default Serial port closing after first sequence.
    Am i doing something wrong? Anyways i set up the schedule and the program. But when the timers start at 5pm the first sequence plays without issue but as soon as the second sequence comes it brings up an error stating "COM1 is unavailable. Access is denied" or something. Any help would be appreciated.
    Sent from my LG-H873 using Tapatalk
    Southern California
    954
    Default Re: Serial port closing after first sequence.
    Are you using Arduino? Arduino IDE is closed?
    Kevin
    Colorado Springs
    3,784
    You might check that the last column of your sequence has every cell 'Off'. If any of them are filled in it an cause Vixen to hold a Com Port open and not allow the next sequence to play.
    Calgary, Canada
    28
    Just checked all of my sequences and none of them have the last column off.
    Calgary, Canada
    28
    Just Checked all my sequences and the end appears empty.
    Feb 2008
    Warminster, PA
    1,712
    Make sure in your program you have the crossfade set to 0 seconds. Anything else will cause an issue.
    Chris
    Calgary, Canada
    28
    Ah, thats it i thought the crossfade would be interesting at one point i thought that might be it. I will change it to 0 seconds.
    Calgary, Canada
    28
    Fixed! Thanks everyone for your help!
