I made up some new videos for programming PICs. They are more detailed and narrated. They show downloading and working with the Renard firmware, and the flash software of the programmer.
With these videos, you will see that programming is a very simple task and something anyone can do. The videos are short and broke up into sections for quick reference. So.... here they are...............
Downloading the .asm file and using MPASMWIN software to create a .HEX file
http://jamesfamilychristmas.com/PICprogram1.swf
Program the PIC using PicKit2 flash software and generated .HEX file.
http://jamesfamilychristmas.com/PICprogram2.swf
New instructions for using the PicKit III by 'mmulvenna'
**** Notes... Links to these videos can also be found in the Christmas Wiki : General Information and Tips ****Okay folks here it is. Dont be too critical as I threw it together pretty fast. This is only to program the chip using the "HEX" file. The first few screens would be the same for the "ASM" file but then you should be able to use Waynes videos for the "project creation".
EDIT: You should also be able to use this for the diagnostic firmware, just change the file name that you select in the file browse.
Hope this helps... and good luck. Happy PICkiting
Old man Mike
http://doityourselfchristmas.com/for...4&d=1264521468
I sat back in my chair with a sign of relieve and said: That was easy!
