I believe KC stated it was only 1 high and 4 wide...
jeff
I know the led triks controller can run 4 signs. Can we configure different layouts within vixen. examples below
1 high 4 wide
2 high 2 wide
4 high 4 wide
jeff
Please consider becoming a Supporting Member of DIYC. Show your thanks to those who make this place possible.
Oh well.....
KC if you taking requests?
This one's been on my mind because after someone mentioned it the first time, I started kicking myself for my short-sightedness in design. It's going to take some work in the editor and output plugins, not to mention the scripting module. So, yeah, I do want to make that change, just not quite yet.
thanks for looking into it
Sounds like I'll need to get more PCBs made ;-)
25 have been sent out to testers so far.
KIWI has the first 1 x 2 panel setup. I have seen the video of his panels running with the same graphics on both boards .i.e they were running with the same address and Vixen was send the same data to both boards at the same time (think two boards, like two channel mono).
KIWI found a problem with addressing board 1 and board 2 (it crashed), but the mighty KC was going to come thru with a patch overnite.
That particular bug has been fixed, but it's part of a large update that's coming down soon. However...there were a lot of changes behind the scenes to the LedTriks plugin, so I am a bit nervous about sending out an update that I can't really test.
But, as usual, if I break you, you will be sure to let me know.![]()
