Results 1 to 10 of 11
Thread: DMX Projects List
    WI
    2,612
    Lightbulb DMX Projects List
    If you have created a DMX device for the community please post it here. This thread will act as a single collection of all DIYC DMX projects.
    Be sure to include the name of the project, a brief description and a link to further information. If this is a new project, please post the name if it has one, a brief description and any supporting files or documents.
    NOTE: This thread isn't designed for discussion or comments about these projects please move those posts to a thread in the DMX section of the forum.
    WI
    2,612
    Default Re: DMX Projects
    8 Channel SX DMX relay pack.
    This is an 8 channel relay pack controlled via DMX. It is based on the Parallax SX microcontroller. The SX was used because of its low cost, fast speed, and easy to learn programming language. The chip can be programmed via BASIC or assembly.
    Enjoy
    http://doityourselfchristmas.com/for...ead.php?t=4723
    Malden MA
    988
    DMX Status display panel
    http://www.ardai.net/DMXStatus
    This is a display panel that shows in real time the value of 256 channels (jumper selectable for the first or second half of the universe) on a 16x16 LED matrix. It displays 6 bits of intensty per pixel.
    The discussion that spawned this project is here
    http://diylightanimation.com/index.php?topic=375.0
    New: A bit of hackery and code optimization, and it now does 8 bits per pixel!
    /mike
    Nov 2008
    22
    Melbourne, Australia
    1,079
    Sep 2008
    Baulkham Hills, NSW
    2,608
    Came across this one a while ago.
    it has some nice professional functions.
    http://www.engbedded.com/semitone/diamond
    I understand it is more than what most DYI users want, but it is worthy of mention considering what it packs in. construction is pretty simple also.
    [B][I]Matt[/I][/B]
    WI
    2,612
    Test utility for RPM's USB DMX Pro clone here:
    http://www.doityourselfchristmas.com...?e=57&catid=26
    Nov 2008
    Lexington, NC
    2,165
    Default Re: DMX Projects List
    Somehow the link got truncated or changed since Ben posted it.
    Here's the "new" link - DMX Test Utility
    The URL points the file library here on DIYC.
    Mark
    Hamilton, NJ
    55
    This post is a great idea. I am a long time renard user but would like to switch to RGB DMX. Has anyone pulled it all together in a similar fashion to http://www.doityourselfchristmas.com...nard_Main_Page Back during the renard development, I actually created a spreadsheet that compared each of the available boards including cost of boards and ALL parts and then normalized it to cost per channel. This is a lot to ask but provides a basis for choosing. Anyway, let me thank everyone working on this. The level of dedication to this hobby is amazing - I was fascinated reading the RGB string reverse engineering posts - it was like the birth of a religion. I am still lost in the mire but hope to get a handle on it in enough time to take advantage of a coop of the most user friendly and efficiently priced system. Thanks to you all!!
    -- Mike
    WI
    2,612
    The PropController is an open source single-board hardware platform designed for lighting and prop control. Based on the Parallax Propeller microcontroller, the PropController has 24 I/O pins, can be powered by both AC and DC supplies. Some of things you could control with the PropController include AC Dimmers, Low Voltage DC LEDs, Pixel Strings, hobby servos, and even motors.
    There are two versions of the PropController, RS-485/DMX and Ethernet. The DMX version features a galvanically isolated RS-485 half-duplex interface. The Ethernet version features the WizNet WIZ812MJ, which makes communicating via Ethernet easy. In addition, both versions are designed to be compact and have 4 mounting holes allowing it to be mounted into any enclosure.
    Project Information
